Old 03-05-2012, 10:13 AM   #1
Newbie
pg_rider's Avatar
Rhino sewer hose doesn't fit in bumper -- suggestions?
Just realized my Rhino sewer hose doesn't fit in the bumper -- the elbow fitting is just a tad too big. What do folks use to store their hoses? I think I saw a thread about installing a large tube under the camper to hold the hose -- is that the most common solution?
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 03-05-2012, 10:50 AM   #2
Dave_Monica's Avatar
I carry all the sewer hook-up gear in a plastic tote and store in the basement. I take the bin out at the end of each trip and open to dry out.
Dave
Old 03-05-2012, 10:51 AM   #3
Either intall a PVC tube, or a 4X4 pvc fence post.. The last alternative is a have aplastic bin just for these hoses.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 03-05-2012, 11:36 AM   #4
pg rider
Welcome to the club. I can't get mine in either. my storage tube was a dealer install.
I too got a plastic storage box and put the hose in the box with other fittings, gloves and items I use in connection with black water cleaning. I also got a zipper closure wardrobe bag and put it in the bag before going in the box.
Big bird is offline   Reply With Quote
Old 03-05-2012, 11:51 AM   #5
CLASS "A" Senior Member
cfsoistman's Avatar
Forest River Forums - cfsoistman's Album: Sewer Hose Holder
This is my solution for storing sewer hose.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-05-2012, 12:20 PM   #6
Before I installed the tube-type sewer hose container, I simply ground down the lugs slightly so that the rhino hose would fit in the bumper - still works fine with the ground-down lugs. On the other hand, I recommend using something other than the bumper as a storage place as eventually the inside of the bumper will rust and then abrade your sewer hose, causing holes. (holes in the sewer hose are not a good thing )
...VTX-Al
VTX Al is offline   Reply With Quote
Old 03-05-2012, 12:28 PM   #7
camper_Lucy's Avatar
That's odd, mine fits but i have to line it up with the tabs in the corners of the bumper. It is snug but i do not have to force it in or out.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 03-05-2012, 12:31 PM   #8
we mounted 6 in pvc pipes under the trailer, I put threaded rod thru the end in an x to keep the hose in but let air circulate. The ends we access from have the pvc screw in caps for easy access, I also pitched the slightly to the open end to help any moisture out. They are big enough that I can keep my adapters and couplers in the tubes also.
2007 Cardinal 362bhle 5er
2006 f350 Diesel CC LB 4x4 4.10 locker lariat
1966 Mustang coupe...under construction
2004 Explorer 4.6 awd (16 year old daughters car)
2009 Mazda 6 (wife's ride)
Bunkfamily is offline   Reply With Quote
Old 03-05-2012, 12:34 PM   #9
DAISY BOYKIN's Avatar
Thin wall PVC pipe from Lowe's
I used the thin wall 4" PVC pipe a threaded adapter, a plug, small boat cleat (Used as a handle). Used 4 SS clamps per storage pipe. Ground the lugs on the Rhino hose, cut the "Flap" ears off with hacksaw. All the elbows, clear hose fittings and other fittings are stored in a walmart
plastic storage box with a lid.
Name:	ROCKY & MODS 001.jpg
ID:	10737   Click image for larger version
Name:	ROCKY & MODS 008.jpg
ID:	10738   Click image for larger version
Name:	ROCKY & MODS 009.jpg
ID:	10739   Click image for larger version
Name:	ROCKY & MODS 010.jpg
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-05-2012, 01:56 PM   #10
old guys's Avatar
Mine fits if I line it up with the corners but I have to disconnect the bottom part of the elbow and I store that in a bag in a pail I keep in the storage compartment. Old Guys
Best loved friend ever!!! (greatly missed)
old guys is offline   Reply With Quote
