I have Good Sam and used it twice this past year, both for flat tires. The first one took about an hour to get someone to me and the second time was less than 30 minutes. The first one was a flat on my trailer and the second one was about a mile from my house not towing anything, just a front tire got a hole punched in it. With Good Sam you can use in any vehicle you are in, even if you are a passenger, does not need to be towing an RV or any other reason, even going to the grocery store in your car. I'm sure like yourself I'm to old (80) to be crawling around on the ground unless I got a fob around my neck and push the button and say "help, I've fallen and can't get up".
Coach net is also good, check the benefits for both. As I understand AAA coverage is spotty, never had it so can say for sure. You can also join FMCA (Family Motor Coach Assn) For $50 and they have road coverage for and additional cost, I think $79 plus there are other membership benefits.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
