Last camping trip I noticed an issue where our step would flex really bad and you could see the door frame flexing from where the step mounted in the floor below it.
I thought hey, no big deal, I can reinforce that. I'm a big guy, my wife isn't tiny, we're putting a lot of force on that step which is applying a lot of torque to the floor right there. I'll reinforce it with some plywood beneath there, no big deal.
Well, I dug into it today. The area in front of the doorway was completely rotten out.
You could push a screw drive through that louan, and the 2x6 that the step was bolted to, you could squeeze water out of. I guess my door frame is leaking. yay!
I cut out all the wet area that I could. Further into the camper it was dry, and I got as far to each side as I could. It feels solid beneath the cabinetry on both sides.
I removed the louan and foam. I plan on replacing it with some plywood and really reinforcing that area.
I sprayed it all down with some bleach and I have a box fan going in there over night to help dry it out. Is there anything else I can do before I patch this back up, to help dry any last little areas up, before I seal it shut?
