Old 11-09-2014, 10:19 AM   #1
Rubber cargo floor
How is anyone cleaning the rubber floor in Toy Hauler mine is new but has a while film. I have tried a couple of things nothing works tried wet mop looks good wet but when dry same thing. Dealer must have put something on it because it wasn't like that when I got it.
Thanks Mickey Moto
Mickey Moto is offline   Reply With Quote
Old 11-11-2014, 10:52 AM   #2
Thanks Mickey Moto
no clue sorry, and maybe you already tried this, but if it's rubber, have you tried Westley's Bleach White or some other brand of tire cleaner? I have also had good luck using a power washer on rubber parts to clean them but not sure that's practical inside a TH.
steveh326 is offline   Reply With Quote
Old 11-11-2014, 11:12 AM   #3
mud yapster's Avatar
I just sweep it out and use soap and water but mine doesn't have white stuff on it just dirt. Ask your dealer what they did. Wax on black rubber will turn white.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-11-2014, 08:28 PM   #4
2011 Forest River Stealth
rwtdct's Avatar
I have no clue what the white film is. Can you post some pics.
2011 Stealth CSFCK3214
2003 Ford F250 Crew Cab 4X4 7.3
2011 Polaris RZR 4
rwtdct is offline   Reply With Quote
Old 11-11-2014, 08:45 PM   #5
trbomax's Avatar
We have that rubber floor in our315wp.Weve only had it a week and I know the dealer did nothing to it because the footprints on it are the same as when we first looked at it. Previous to this unit we used a LQ horse trailer for toys.It was all aluminum so it got pressure washed regularly with no problems.The 315 is wall paper over luan all the way to the floor and any hoseing in there will surely lead to problems.Next spring I will bend up some .090 aluminum sheet with a 90 deg lip on the bottom edge,and make it extend up the sidewall a foot or so.I will set it in butal windshield caulk/adhesive along the bottom and top edges.This will keep the water off the bottom edge of the plywood.
trbomax is offline   Reply With Quote
