Old 07-23-2016, 10:30 PM   #1
Loneeagle's Avatar
Run Slide off Truck Battery
I have a 2007 Ford F150. My trailer is a Flagstaff MicroLite 30amp unit. Can I run the awning, slide, AC off the truck battery for Demo purposes for someone interested in buying the trailer?
Thanks,
Terry
Ford F-150 4X4
2015 Flagstaff Micro Lite FRBS
2013 Flagstaff "A" Frame - Traded Up.
Camping Days 2013 - 24
Camping Days 2014 - 21
Projected Camping Days 2015 - 30
Loneeagle is offline   Reply With Quote
Old 07-23-2016, 10:34 PM   #2
Fulltime family RVer
I can on my camper.
But, if they're really buying it, aren't they going to need a good working battery for the tow home?
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 07-24-2016, 06:50 AM   #3
Loneeagle's Avatar
Slideout
Thanks for your help.
The battery is good but low right now.
Ford F-150 4X4
Old 07-24-2016, 07:12 AM   #4
Witch Doctor's Avatar
Thanks,
Terry
I really don't think so, your TV is only going to give you a trickle charge to your unit, Your going to need to have that units battery up to charge atleast. Or buy a 30 amp to 120 v plug that you can get enough juice with to your convertor so it will work. A/C will work off that way, but not from your TV battery. Make sure you have a rated 20 volt outlet when you do this and not a 15 amp outlet when you do that for the A/C. Remember the controls for the A/C are 12 Volt but the compressor is 120V at 17 amps. Did I understand your post correctly?
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-24-2016, 07:43 AM   #5
jtstromsburg's Avatar
I can on my camper.
Agree with ependydad. I had battery problems on my 3 slide 5th wheel last year and when time to break camp, not enough juice to bring in slides or raise jacks. Conveyer wasn't keeping up either, but as soon as I plugged into my truck I was able to bring in slides and raise jacks.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-24-2016, 07:56 AM   #6
Blackrock's Avatar
You might try jumper cables direct from the truck battery to the trailer battery. You can get more volt/amps through than going through the inverter.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 07-24-2016, 03:42 PM   #7
I, too, have a MicroLite. The trailer's battery operates only the stereo and ceiling lights. Hooking into my F-150 only adds the exterior lights. I have to plug into a 30 amp power source to run the AC, slide-out, electrical receptacles, and residential refrigerator that I installed. This forum advised me to purchase a 3500 watt generator to equate to shore power.
Hector517 is offline   Reply With Quote
Old 07-24-2016, 03:49 PM   #8
Loneeagle's Avatar
Thanks,
That's very helpful.
Ford F-150 4X4
Old 07-24-2016, 03:52 PM   #9
You are not going to run an A/C off your truck battery Your slides might work if you still have any juice in the batteries but as the OP asked AC. I don't care if you have an inverter for 12v to 120 volt it will not work off your TV alone. You can not get the amperage you need from your TV plug. So I agree with Hector517. Espendydad explain how you you could run a A/C off your Tow Vehicle battery? That is what the OP asked also?
Old 07-24-2016, 03:52 PM   #10
Moderators' Assistant
bikendan's Avatar
Not true.
The battery also powers the bathroom fan, the furnace fan and igniter, the water pump, the water heater igniter, the fridge electronics and igniter, slideout motor and power tongue jack.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
battery, slide, truck
