06-08-2019, 10:59 PM
Running the refrigerator at storage?
We are In a open air covered storage. What is the general though on running the refrigerator on gas for a day or two before picking it up. I feel it is ok but the DW is concerned. Any thoughts?
06-09-2019, 03:13 AM
World Wide Wanderer
I don't see an issue with it unless it is brutally hot and there is no air moving.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
06-09-2019, 08:17 AM
Just remember there is an open flame if your running refrigerator on gas. I personally would not run it in storage cause anything could happen and you would be responsible for any damage to others property. I always take my camper home a few days early so I can cool down refrigerator and that way I can keep an eye on it and it wouldn't damage others property. Just my 2 cents.
06-09-2019, 09:56 AM
Aaron
We are in Florida so brutally hot is an every day thing.
06-09-2019, 09:58 AM
This is my wife's thought also. We normally do and will also I was just thinking a head start would be nice.
06-09-2019, 10:02 AM
completely different response, but i am impressed with your ability to get the trailer into that enclosure. those little diagonal braces in the top corners sure look intimidating to me.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
06-09-2019, 10:07 AM
It is a very tight fit. But with the dw as a spotter it isn't so bad. I can even do it on my own if I take a few extra minutes.
06-09-2019, 10:13 AM
Why worry about running the refrigerator while in storage. Everyone runs it while they're living in it, especially while sleeping at night. Why not worry then?
That flame isn't exactly an open flame as it's shielded from pretty much everything around it. As for flammable vapors, most are heavier than air and refrigerators are mounted high above the ground.
There's no more risk while your TT is in storage than while using it.
06-09-2019, 12:04 PM
Since you are asking about running off of propane, I presume that you don’t have electricity in storage.
So, some (maybe all) refrigerators still rely on some amount of electricity, like your battery. If you shut off the battery disconnect, or battery goes dead, the refrigerator may shut down.
06-09-2019, 12:06 PM
x2 on TitanMike's comment. Run it.
McCormickJim
2017 GT 31L5
06-09-2019, 12:23 PM
X3 on Titan Mike. We run ours in front of our house the day before we leave, and while driving without problems. Unless you have gasoline or other flammable fumes in close proximity, I don’t see an issue.
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
06-09-2019, 12:35 PM
Refer
I'd run it. Flame is brutally small. Get a start on cooling it. Just make sure the RV is level!!!
06-09-2019, 01:50 PM
I have considered that also. Just water on site. I dont think I'm to concerned with the battery power for 2 days. We have 4 group 24 batteries. I know they aren't true deep cycle but feel that wont be to much drain.
06-09-2019, 01:51 PM
Yes for sure. The storage is pretty level and I don't have to worry about water run off.
06-09-2019, 03:02 PM
I would not worry too much about any open flame issues. I run mine on propane even when refueling my truck.
06-09-2019, 03:25 PM
Gasoline vapor flows across the ground like water when unconfined so little chance of a any RV pilot or refrigerator flame lighting it off as long as its over a foot off the ground.
06-09-2019, 04:25 PM
Newly Retired
No problem
I see no concern about running the fridge on gas while parked. I have used one parked for months since I put a solar panel on the roof. Without 110 power you are depending on the battery staying above 11 volts or so to keep the flame going. 12 hours should be enough time to cool it down enough for food. If your battery is not already weak when you try to start the fridge, you should be fine.
06-09-2019, 05:28 PM
If she's worried about the propane issue, you're probably not going to win the argument. You certainly don't want to live with the 'I told you so' if something goes wrong.
Instead, freeze some gallon bottles of water or use some frozen freezer packs and put them in there to precool the fridge and freezer. I'm making the assumption that what you're trying to do is to precool the unit prior to putting food in there.
2015 Dynamax REV 24TB class C
06-09-2019, 08:37 PM
Not a bad idea. Its coming home Thursday we leave Saturday morning. I was just thinking if I run it Wednesday I would get a head start. I'm sure we will bring some sort of ice cream so I wanted to be cold cold. Last time we brought some of the liquid type ice pops they took 2 days to freeze after flipping them twice a day.
06-10-2019, 08:14 AM
If your fridge is a Dometic, it probably has the door seal heater strips in it. This heater uses more DC power than the control board. If you take the cover off of the control board which is outside the rv, you can disconnect the "light/heater" wire. I normally do this when boondocking or precooling the fridge before a trip.
Phil
