Old 02-14-2012, 11:33 PM   #1
DC_In_NC's Avatar
RV Anti-freeze issue.......
Hope everyone is well. A friend told my wife that using RV anti-freeze is dangerous and we shouldn't drink the water after it's cleared from the lines and will absorb into the plastic water lines and ruin them. She stated tonight at dinner "she and our kids will never drink for the camper faucet again." Need help convincing her that is not true or is she right for once?
Thank you in advance!!
DC
North Carolina
DC_In_NC is offline   Reply With Quote
Old 02-15-2012, 12:21 AM   #2
Not true, plain and simple. Flush the system, then sanitize if you wish, (do a search on here), and enjoy.
During the last years of Andy Rooney on television, I caught a report of bottled water verses fountain water. 99% of the time, fountain water from a public place, mall or store restroom area, was better and cleaner than most of the major brands of bottled water.
I'll throw one other thing out here, quoted from first post, "A friend told my wife......".
Now is this friend an expert in the healthcare industry? Does this friend have any chemical engineering degrees? Does your friend have any proof that someone got sick, or terminally ill from drinking water from an RV that had antifreeze in it? Don't get me wrong, I'm not being down on your friend, we all here and read stuff, like all the experts that sprung everywhere on Y2K, that the world would end, computers would crash, the economy would be gone, the power grid would die, well, you remember.
In this day and age, I believe nothing I hear from and friends and neighbors. I believe little of what I read, and only half of what I see.
By the way, how is your tire wear with the new axles?
Hope it is OK.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-15-2012, 02:03 AM   #3
flyrotor's Avatar
Ditto, it's a myth, kind of like the diet soda turning to formaldehyde once it reaches a specific temperature in your body, if that's the case, I have already taken care of my embolming and will not need the services of a mortician when I die, or I should have already died from it, along with millions of others.
flyrotor is offline   Reply With Quote
Old 02-15-2012, 04:03 AM   #4
amxpress's Avatar
Here's the MSDS for Peak RV anti freeze. Hazards ID is rated a "0", can't get no lower than that.
http://www.peakauto.com/pdf/msds-peak_rv_marine.pdf
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 02-15-2012, 06:43 AM   #5
Wanna Be Camper
SaskCampers's Avatar
RV/Marine non-toxic antifreeze is probably the most misunderstood commodity in the RV industry. There are currently three different varieties on the market at three very different prices.
Ethanol (alcohol) based: This type of antifreeze is most readily available in hardware stores and most RV shops it sells for approximately $3.00 - $4.00 a jug. However, this product is also extremely flammable and not to used around any sort of pilot flames or cigarettes. As well, this product has been known to taint certain RV plumbing systems and is only to be used with Quest or Pex plumbing lines. If you have ever used this product you will quickly remember how bad you water smelt and tasted the next spring. Furthermore, because this product is made from alcohol it works to dry out all the rubber seals readily found in your faucets and toilet.
Propylene Glycol based: This product is usually only available at your local RV shop (and not every RV shop for that matter). It sells for approximately $5.00 - $6.00 a jug. Like the ethanol antifreeze, this product is non-toxic and safe for all RV plumbing. However, propylene glycol does not have the same fire safety warnings, nor the risk of tainting your RV plumbing system. Furthermore, propylene glycol is a lubricant and will actually work to extend the life of the seals in your faucets and toilets, unlike the ethanol based products
Propylene/Ethanol Blend: Again this product is non-toxic and completely safe for RV plumbing systems. It will cost more than $4.00 - $5.00 a jug. This may seem like a good idea, however, it is unknown how much ethanol is required to taint RV plumbing lines and dry out plumbing seals.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 02-15-2012, 07:20 AM   #6
Oakman's Avatar
Once your wife believes what a "friend" told her you will never convince her otherwise. Just bring gallon jugs of bottled water for cooking and coffee, etc.
BTW her friend is an idiot, plain and simple.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-15-2012, 07:42 AM   #7
MtnGuy's Avatar
I have water listed as an ingredient in the RV antifreez that I use, and even that has an MSDS. Included are these 1st Aid instructions:
Eyes: If irritation develops, get medical aid.
Skin: Get medical aid if irritation develops or persists.
Ingestion: Get medical aid if irritation or symptoms occur.
Old 02-15-2012, 07:46 AM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
Hope her friend doesn't tell her that bleach can be used to sanitize the lines or she'll be afraid everyone's hair will turn blonde and all colored clothes will be fading instantly if you use the water.
Nice knowing you all. I made coffee when camping and ..........
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 02-15-2012, 08:08 AM   #9
KyDan's Avatar
We are in FL as I type this. Drove down here on Friday with Pink RV antifreeze in
all the lines. Once here I hooked up to local tap with a filter and flushed the lines.
Some foam on the first day or 2. After that no foam, no taste, just good water.
We're drinking it and making coffee with it.
I do this every year.
RV antifreeze is safe and we have had no issues with residual taste beyond a couple
of days when we first start up the water system.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-15-2012, 09:41 PM   #10
Lottery Non-Winner
Ovair's Avatar
Show her the jug. It says non-toxic right on it.
Tell your "friend" about dihydrogen monoxide and let them go nuts trying to stay away from it.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
