Old 05-15-2016, 02:57 PM   #1
RV carports
Hello. I am looking at getting a new carport for our 2011 Sunseeker. Wife and I have narrowed down the brand between Carolina carport and Eagle carport. We are looking at 12 x 36 x 12 high with sides and back enclosed.
Has anybody had good luck with either brand?
Thank you,
Randy
rhughsless is offline   Reply With Quote
Old 05-15-2016, 03:16 PM   #2
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
12 ft. Might be a bit tight, depending your heights. I would suggest 13.5 or 14. Gives a bit of room for taller rigs, and may even allow you to do some basics to the roof while covered. Of course, your results may vary.....
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 05-15-2016, 03:21 PM   #3
Long Leaf Piners's Avatar
Since I'm interested in covers, too, I just took a minute to Google both types you mentioned. It was a bit surprising (at only 2 and 2.5 stars) to see the results.
Seems hugely dependent on the installer you have, so as Paulie1138 said, your results may vary.
2014 8528 IKWS
Ford F-250 Diesel
Cricket the Cairn and Sally the Terrier Muppet Mix
Long Leaf Piners is offline   Reply With Quote
Old 05-15-2016, 03:27 PM   #4
Mr. Dan's Avatar
I used T-N-T Carports - Nationwide installed metal carports, garages, buildings, rv covers, horse barns, lean-tos and more! and have been very happy with mine. My RV shed is 40' long by 18' feet wide with 12' side legs which makes the center peak accommodate my 13' 6" or so trailer. My side walls are covered from the top half way (6') down. Here in Texas, I left my ends open so our strong winds wouldn't blow the shed away like a para-sail.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-15-2016, 03:29 PM   #5
Recently new!
Paulie1138's Avatar
Carport
To add, I built my own from structural steel and a wood deck. 30'x40'. Perfect spot for my 10 kW solar panel array with room to grow.
2001 Ford F-250 7.3
Old 05-15-2016, 03:48 PM   #6
Had one put up fall of 2014 by All Steel Carports out of Muncie, IN. Best pricing I could find, solid reputation locally, good warranty. The work in a several state area.
Couldn't find a good pic on my camera, but here's one. I went with 18 x 40 with 12' side walls, fully enclosed back and sides.
I also ordered extra parts and made out-swinging doors for the front. The rationale is that this preserves my full height. With the roof slope, I have well over 14' of clearance at the center. For the middle 12' of the building, I have 13'6", max height allowed in the road.
Oh, and the 18' height also lets me open slides on both sides of the unit at the same time.
Good luck w your decision.
Brian, Stacy, and the girls (11 and 8)
2011 F-250 CCSB 6.7L PSD 4WD
2013 Solaire 269BHDSK
ProPride Hitch
purduepete97 is offline   Reply With Quote
Old 05-15-2016, 04:19 PM   #7
Steeljag's Avatar
As stated above, if the side walls are 12' and the center is higher you should be OK. I believe the height of the Sunseeker class C is 11'4".
If possible you may want to 14' in both height and width.
Good luck.
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 05-15-2016, 04:44 PM   #8
Rv Carports
PurduePete97
I looked at those online. Unfortunately I live in western Pa. and they do not install or supply to my state. Thank you for the response.
Paulie1138:
I have talked with both representatives of the carports and they both said I should have 13.5' in center. I only need to clear 11.4' with the A/C unit. Thank you for the response.
Mr Dan.:
I looked up TNT as I have never heard of them before, turns out I have 3 dealers within 20 miles of my home. I am going to call one tomorrow. Thank you for the info.
This is why I love this forum
Old 05-15-2016, 04:47 PM   #9
Steeljag
You are correct. My height is 11.4' with the A/C unit. I have a cover it shelter now and it is 11 yrs old and pretty worn out. The wind really does a number on the vinyl tarp. The reason I am going with 12' wide is that is what I currently have leveled off.
Thank you for your response.
Old 05-15-2016, 05:24 PM   #10
Citrus County, Fl.
GL1800Rider's Avatar
Mine is 36' long, 16' wide, 12' high at the sidewalls and 14' at the peak. Originally ordered it for our TT with wider slides but it had to be perfectly centered. Our Forester fits perfect and both slides can be open with room to spare. I also went with a 4' panel on the sides to help keep the sun off the roof.
It was built by Orlando Steel but I am certain they don't do business up in Pennslyvania
ID:	107972   Click image for larger version
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
