Old 10-19-2014, 09:52 PM   #11
I'm looking for a cover for our 2014 Wildwood xlite. Adco has several different types of covers. Are the tyvek covers twice as good as the others? They are almost double the cost. I don't mind paying for quality but don't want to waste our money either.
laurarice26 is offline   Reply With Quote
Old 10-19-2014, 10:32 PM   #12
ColoradoRick's Avatar
If you get winds greater than 45 mph then you may want to reconsider. Here in Colorado, winds of 60+ are not uncommon so covers end up shredded and they, also, can do quite a bit of damage to the RV.
I am going to see if an A/C cover will survive the winter and, also, putting on awning covers, as well as the wheel covers and I have a little cover over my electric tongue jack.
You best bet would be to ask your dealer. (Mine doesn't even sell covers for the above reasons.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-20-2014, 06:53 PM   #13
Laura, I recently purchased the ADCO Designer Series cover for my TT. I chose this modelbased on the chart on ADCO's website. Up here in Wisconsin you need one that is extremely durable and designed for high sun exposure, high moisture, and snow. This one fit the bill. I was impressed with the DuPont Tyvek fabric as compared to other covers I have purchased in the past. Hands down this is the best I've seen for the money. I don't know about cost being doubled but I do know there are other manufacturers out there more expensive and less expensive. I chose to go in the middle and after reading some of the reviews in this forum. I don't care which cover you get, be sure to reinforce anything that can tear or rip a hole in the cover. As Colorado Rick stated above, winds can cause damage so you will want to snug things up and protect corners. Tip: I used those foam "noodles" kids use to float around in water to cover sharp corners to protect the cover. You can easily cut them to fit any corner or sharp object. Good luck in your endeavor to purchase a cover.
2015 Rockwood 2703WS
2014 Ford F250 SRW 4X4 Crew Cab
Lariat 6.7L Power Stroke V-8 Diesel
Equal-i-zer WD system- 12K lbs GTW, 1,200lbs TW
Ancha71 is offline   Reply With Quote
Old 10-20-2014, 07:01 PM   #14
Platokidd's Avatar
Permapro
Permapro by classic accessories
RV PermaPRO Travel Trailer Cover - Travel Trailer & R-Pod - RV
Light weight, easier to install and holds up to the windy winters we have here in Chicago land.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 10-27-2014, 12:46 PM   #15
harleyguy's Avatar
Just put on our new Adco tyvek cover on yesterday for the first time on our Coachmen Freedom Express 281 RLDS. It took maybe 35 minutes to figure it out and install. We were having 25 to 30 mph wind gusts while installing so I was a little nervous but was able to get it on with no problems. I put the tennis balls on the gutter ends to help eliminate the tearing. I have my trailer parked on our Michigan up north property which is located in the snow belt of our state so hopefully this will help with protecting the finish. I will do a post next spring to review the covers wear.
harleyguy is offline   Reply With Quote
Old 10-28-2014, 04:59 AM   #16
Toy-aholic
I had an Adco that lasted 2 seasons before tearing...did some research & got a Goldline and let me tell you the quality is not even comparable...looks like this thing could withstand just about anything. We had a nasty winter last yr & it shows no issues whatsoever.
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
cover
