05-06-2017, 07:12 PM
RV covers - Yea or Nay?
RV covers - are they worth using?
Our last rv had an issue with black steaks running down fruition the roof. I never was able to get them off (it had aluminum sides.)
Fast forward to new rig.. It's fiberglass and I intend on waxing it.
Should I buy a cover for when I'm not using the camper or will the wax be enough to keep streaking at bay?
I don't mind occasional cleaning if the steaks come off without major effort.
-- My wife complains I never listen to her. Or something like that.
2017 Heritage Glen 368RLHBK Limited
2017 Ram 3500 4x4 Crew, 6.7 Cummins
05-06-2017, 07:17 PM
Two words: hell yes. Get the best cover. From experience, it will add years to your roof, seals, appearance.
05-06-2017, 08:05 PM
Yes
05-06-2017, 08:08 PM
Yes and no. No, if you keep it inside like I do and yes if it's outside with this caveat... Stand the cover off the roof if the cover is on the unit for an extended time. Use .40 retention 2x4's cross ways to keep the cover and the roof seperated for air movement.
05-07-2017, 12:27 PM
New TT Owner
Not intending to hijack this thread but I've been looking for covers and am in need of your assistance. We live in KY and our new Rockwood Mini Lite is parked at our house in full sun. We get all kinds of weather, wind, humidity, rain, and snow. I'm torn between which cover to purchase and I understand the sun will damage the cover.
What I'd like to know - for those who have used and are currently using covers, which cover did you purchase and why?
I certainly would appreciate any advice you can give me. I am trying to purchase the best cover for our area and situation. The local RV dealers only carry the Aquashed but I've found so many more online and know I'm totally overthinking it. But like others I want to keep our TT looking good as new if possible.
Thanks for your input.
05-07-2017, 12:28 PM
I have been using an Adco cover that I ought 2years ago and didn't start using it about 7 months ago. it's a bit of work but a lot less then the scrubbing I have to do when I take it out of the storage yard. One tip I can give you that I learned after the first time I used it. Put tennis balls on the gutters and awning protrusion, will save you from getting holes.
05-07-2017, 01:52 PM
I don't think this is a hijack. My next question would have been "which kind"?
05-07-2017, 02:05 PM
Depends where you live. Here in California the sun damages fiberglass regardless of how much wax you put on. RV's and boats must e covered. Better yet, store it indoors.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
05-07-2017, 02:09 PM
Also California sun kills the decals.
05-07-2017, 03:11 PM
Actually, a cheap Harbor Freight poly tarp works fine so long as you stand it off the roof (like I explained in an earlier post and secure it properly so it don't flap. Flappiing tarps mar the fiberglass sides and destroy the decals..
05-07-2017, 05:54 PM
This is the first year I didn't cover my 5er, only reason is the wind last spring totally destroyed the ADCO cover I had and it was as tight as can be when I put it on, and I wasn't going to buy a new one because we are trading up this year to a bigger 5er. After seeing what one winter will do to a camper I definitely will buy another cover for my new 5er. Yes it's well worth the money.
2012 Ram 3500 CC Limited Cummins TD
2011 Flagstaff 8528 BHSS ( for sale )
1968 Dodge Coronet R/T
05-07-2017, 06:01 PM
Back at the beginning of this past winter, many many questions were asked about whether to cover or not and most were directed toward snow problems. So many said "Don't cover, let the wind blow the snow off" or "Use a leaf blower to blow the snow off". Well, it was my assumption that many of these people had never seen a real snow storm or knew that there are many different 'kinds' of snow ~ dry, powder, wet, slushy, etc. Now, if a 40 mph wind won't blow a heavy wet snow off and the temp is supposed to go to -0*F the same night, what chance does a leaf blower have? For me, I looked for a roof top bra like used on a Class A but couldn't find what I wanted. I ended up getting a white polly tarp, just wide enough to cover the awning roll and go over the other side and long enough to slightly cover both ends. I tied the tarp down and as the snow deepened, I was able to gently pull it off about 3 times during the winter without difficulty. It's still on there as of now, easy to remove, we're still having rain and high wind gusts almost daily and have noticed no damage to the siding or decals, very light black streaks most likely before I got it covered. Also, lots of pine & fir tree needles along with leaves, I'll continue to use it.
05-07-2017, 06:26 PM
I love my Sunbrella Calmark cover, it was very expensive though. I had a Chinese cover and the sun deteriorated it in 5 months!
2016 Coachmen Apex 288BHS
2015 F150 Sport 4x4 3.5 Eco Boost
05-07-2017, 07:16 PM
Two year ago, we bought one of the best ADCO covers available. Even though we followed directions by padding the bumper corners, it ripped through in less than a week. We left the cover on for part of the Winter, i.e. before the wind blew it off. True, sharp corners will cut through about any material, but the plastic buckles that attach the straps do not hold under stress. When one gives, they all give. ADCO did replace it under warranty without having to return the damaged cover. We never put the second cover on.
Be warned, even the lightest covers get pretty heavy when trying to stretch it across the roof and down the sides. Even in a breeze, they have a tendency to kite.
If doing it again, I would strongly consider a Sunbrella material. The material is much more substantial and a custom made cover should have better attachments. But then the price will be about 5 times plus the price.
05-07-2017, 08:07 PM
Working at retired:D
FWIW I use an Adco cover when my camper is not in use even with it parked in a barn. Keeps dirt and bird droppings off. If it was left outside in winter I'd cover it. To many water leak stories out there. Although I don't think my cover would stand up well to weather. Probably would have to go to a better material. Does take 2 people to install.
2017 Wildcat 301RES - 2017 Ford F-250
05-07-2017, 09:09 PM
Don't go with ADCO, they only last a year or so. Elements is much more durable. Buy when on sale at Camping World.
Gary and Donna
Trail Air pin box
Demco AutoSlide 18k
05-07-2017, 09:23 PM
Neither wind, nor rain, nor sleet, nor snow can do the damage ultra-violet rays can. I have had great success with the ADCO cover here in Ohio. BTW, I highly recommend you also cover the tires for the same reason.
2018 Berkshire 38A
05-07-2017, 10:50 PM
Yes we wash and cover after every trip.
05-07-2017, 11:25 PM
I live in southern NM and we also spend a lot of time in southern AZ. Yep, sun does damage your rig, but not as much as any cover we have tried to use. Haven't seen any cover that lasts more than 2 years down here in the desert. And no matter how tight you get the cover, it will leave rub marks.
So we don't think covers are worth the time and money.
Our rig is 6 years old and still looks great. We use a good wax and rubber roof treatment that has UV protection in it. Do the rig twice a year.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
05-08-2017, 12:15 AM
New RV Owner
Following
Rob & Julie
2018 Coachmen Catalina 323BHDS
2016 Nissan NV Pass 3500HD
