Old 02-08-2014, 10:52 PM   #11
Not like this!Youroo!!
Old 02-09-2014, 07:58 AM   #12
Yeah not like that. It will be well protected from the standpoint it will be right along my house and then the neighbor has the same amount of space and then his house. I live in SoCal so when we say RV parking it is really just wide enough for the RV. Basically tract homes with a little extra room on the side.
Looking for a new rig!!!
2013 Georgetown 329DS - SOLD
2017 Jeep GC Trailhawk TOAD
Klamaths Premium "Porter" JH RIP
Raney's Blazin' "Baxter"
All white Siberian Husky "Turbo"
goin2drt is offline   Reply With Quote
Old 02-09-2014, 07:25 PM   #13
1500 dodge's Avatar
I bought a used rv carport on Craigslist. I bought tarps and hung them all around to block the sun. I slide the front one back like a shower curtain when we head out on trips. Click image for larger version
Name:	ImageUploadedByForest River Forums1391995457.989188.jpg
ID:	46036Click image for larger version
Name:	ImageUploadedByForest River Forums1391995473.497861.jpg
ID:	46037Click image for larger version
Name:	ImageUploadedByForest River Forums1391995491.088919.jpg
1500 dodge is offline   Reply With Quote
Old 02-10-2014, 10:43 PM   #14
1l243's Avatar
We just had a 41x20 Metal RV Port built last week. It is the classic style with enclosed back and an extra 3 feet down the sides. Cost was about $4800. The company we bought it from provided the engineering plans because I was required to get a permit. Another company wanted to charge alot more for a certified kit.
Ours is rated 110mph and bolted to concrete slab. I had to have the pad poured first. These guys came right out and put it up in 5 hours on time and did good work..
Check your city and county for permits and restrictions...Just because you have room does not mean they will let you put up a cover..
Pacific Metal Buildings
1l243 is offline   Reply With Quote
Old 02-11-2014, 09:39 PM   #15
mkford1953's Avatar
Originally Posted by Ford Idaho View Post
We bought one for our 24 TT...........5th wheel will not fit under.......
Thinking of extending the legs/poles 2 ft with square alum poles. Would be way cheaper then $2500.00 for another one.
mkford1953 is offline   Reply With Quote
Old 02-11-2014, 09:40 PM   #16
mkford1953's Avatar
Originally Posted by eisbell View Post
Attachment 45991here is ours. Could you do something like this but not as wide? Ours is 41x18
Nice
Old 02-11-2014, 10:39 PM   #17
Ford Idaho's Avatar
Added on to the bottom?
I would be tempted to go a little longer and double bolt the extensions one from each side about 6 inch's apart and 4 inch's from the top of the extensions.
I agree using the one you have is way cheaper.
Old 02-12-2014, 07:12 PM   #18
mkford1953's Avatar
Thanks for the tip.
We have a friend that has a backhoe tractor. We will use the bucket to lift each side up one at a time. Jim will drill and bolt the extension legs to the original legs. the frame is bolted into the concrete. Maybe harder then we think.
Old 02-12-2014, 07:18 PM   #19
Ford Idaho's Avatar
Thumbs up
Thanks for the tip.
Just be sure to chain things tight but loose enough to maneuver a hair or three.
Good luck.
Old 02-12-2014, 07:31 PM   #20
1l243's Avatar
I don't think you will be able to lift one end at a time to extend the legs. Watching the install of mine the trusses have to be dropped directly on top of the legs or base. If you are at a angle like lifting just one end you will bind up. When I called the installer to have the RV Port at my last house raised four feet they said it had to be taken apart and then reassembled. It was too costly. About 1500$$ to raise a 18x36 ...
cover
