Old 09-09-2014, 07:32 PM   #1
RV Slideout Stabilizers Work Great
I purchased 2 pairs of Husky 81080 slide out stabilizers and was surprised how much they took out the rock and roll of my 2703WS when someone walks on the floor. They are extremely easy to install and remove. Just make sure your knees are flexible enough to squat while placing the stabilizers under the slide out rails.
2015 Rockwood 2703WS
2014 Ford F250 SRW 4X4 Crew Cab
Lariat 6.7L Power Stroke V-8 Diesel
Equal-i-zer WD system- 12K lbs GTW, 1,200lbs TW
Ancha71 is offline   Reply With Quote
Old 09-09-2014, 07:35 PM   #2
Originally Posted by Ancha71 View Post
I purchased a pair of Husky 81080 slide out stabilizers and was surprised how much they took out the rock and roll of my 2703WS when someone walks on the floor. They are extremely easy to install and remove. Just make sure your knees are flexible enough to squat while placing the stabilizers under the slide out rails.
And hope the trailer jacks don't settle and put the slide in a bind or have a flat tire while parked. Slide out stabilizers can cause you a big headache if the trailer settles any at all.
Old 09-10-2014, 07:29 AM   #3
cpaulsen's Avatar
X2!
cpaulsen is offline   Reply With Quote
Old 09-10-2014, 07:57 AM   #4
X3. The dealer who sold us our last two campers advised us not to use them. You're better off using jack stands in front of and behind the tires.
Old 09-10-2014, 10:19 AM   #5
Fulltime family RVer
Most likely the owner's manual also advises against them.
Old 09-10-2014, 10:38 AM   #6
raspivey's Avatar
I'd invest in some cheap screw jacks to place on the frame under the slide in case it settles any. Less likely to get in a bind that way.
slide, stabilizers, slide out
