Old 08-27-2016, 10:24 PM   #11
WFD
I had been using 5/8 for the last 3 yrs and needed a new hose on our current trip and got 1/2 cause they had lots of it and a good price. I haven't noticed any difference over the 25 ft I have ran it...perhaps I would over a longer distance. Keep in mind that as soon as the water reaches the trailer plumbing it's all 1/2 inch anyhow.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-27-2016, 11:28 PM   #12
Originally Posted by fella10 View Post
keep in mind, you're in an RV not at home in a house, we carry a 10' and 25', ... both are 1/2" and provide all the water and pressure we could ever want, a 5/8" hose is just more bulk,... I use the 10' if I can, the 25' if I can't, and the 35' if needed,.....
More bulk?!? Come on, man! We carry two 25 footers. Most of the time one will work, but sometimes I hook up both just to be able to put them under the RV and out of the way, depending on where the pedestal is.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
tdst51 is offline   Reply With Quote
Old 08-27-2016, 11:44 PM   #13
yes, a 5/8" hose is more bulk than a 1/2" hose, duh??.... to each, his own!...... maybe you need a large hose?,.. but all of us aren't towing a 32', 9,000# 5er,..... so for some of us, a small hose works just fine!.... and I would also imagine that thru that large hose you only get "all the water that you need", and to your surprise, we get the very same amount thru our small hose, thru it we get "all the water that we need",... how about that? .......
fella10 is offline   Reply With Quote
Old 08-28-2016, 01:22 AM   #14
chop249's Avatar
Originally Posted by boondocking View Post
A 1/2" hose 25' long @ 40 psi = 24 gpm.
A 5/8" hose 25' long @ 40 psi = 44 gpm.
There is quite a difference there.
And all your fixtures are most likely water conservation fixtures at 1-2 gpm. You could turn on every faucet in the rv wide open and still not reach 24gpm. In addition if you're in a site without sewer, do you really want to fill your holing tanks that much faster and have to either pull down to the dump station or use one of the dump dollies?
Bob
2011 Ford F350 Lariat
2016 Sandpiper 381RBOK with an extremely CRAPPY A/C!!!
Nights Camped: 2010 = 14/11 = 27/12 = 13/13 = 10/14 = 30/15 = 47/16 = 30/17 = 4
chop249 is offline   Reply With Quote
Old 08-28-2016, 02:35 AM   #15
So you figure using a larger hose will cause your holding tanks to fill up quicker? I think maybe I will switch to a 1/4" hose then.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is online now   Reply With Quote
Old 08-28-2016, 09:54 AM   #16
chop249's Avatar
If you manipulate the fixtures and remove the water saving portion, yes they will because you can then supply 44gpm.
Bob
Old 08-28-2016, 12:45 PM   #17
2007 Surveyor SV230
Old 08-28-2016, 01:17 PM   #18
davel1971's Avatar
you can use a fire hose if you want, you are still limited to the same flow from the small pipes and low flow faucets inside the RV
David & Lynn
Old 08-28-2016, 01:45 PM   #19
To the OP
Bottom line is you will have the same water flow out of your faucets whether you use 1/2" or 5/8".
2007 Surveyor SV230
Old 08-28-2016, 01:49 PM   #20
BandJCarm's Avatar
To the OP
If that's true, and if outside flow is immaterial, then why is a regulator suggested to be put in the line outside????????????????????
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
water
