Old 03-12-2015, 05:17 PM   #1
Safe Awning Practice
I rarely use my awning because I do not want to damage it. So with that said, what are some guidelines for using the awning, acceptable wind conditions?
Thanks,
Randy
Randy from Texas
TV - 2014 Chevy Silverado
TT - 2014 Palomino Puma 28DSBS
Randy in Texas
TV - 2013 Ford F-250 PS Diesel
Grif76040 is offline   Reply With Quote
Old 03-12-2015, 05:20 PM   #2
Platokidd's Avatar
This works good for me. Had my awning out in 35mph winds no problem. Tie strapped down though.
Awning pole hold down kit - Page 115 - Forest River Forums
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-12-2015, 05:24 PM   #3
Not much Info? Common Sense is the Best Rule for Awning Deployment,Manual or Electric! Youroo!!
Old 03-12-2015, 05:56 PM   #4
That's a little difficult to answer. It's somewhat dependent on maker, material, size.. etc.
Platokidd already referenced OC's tie-down pole kits. Those are a Godsend. You might also consider using deflappers. I have a 15' electric, use the 'max' type deflappers and O.C.'s pole's and very rarely pull my awning in. I've had it out in 35-40mph gusts without any problem, but common sense has to play a role. If you are getting a lot of 'action' in the awning, it's probably a good idea to roll'r up.
My main concern isn't so much about when it is deployed, but unfurling when traveling. I use an awning clamp which has seemed to work well so far.
rana is offline   Reply With Quote
Old 03-12-2015, 06:21 PM   #5
I made my awning "Unfurling" device. Have another that just slips in the sunscreen slot and holds the same way.
Name:	Alum tab for awning lock.JPG
ID:	71224   Click image for larger version
Name:	Alum tab, 3-8 x 1-2 ss bolt, washer & nyloc nut.JPG
ID:	71225   Click image for larger version
Name:	Awning lock top bracket.JPG
ID:	71226   Click image for larger version
Name:	Awning lock turnbuckle.JPG
ID:	71227   Click image for larger version
Name:	Bottom hook unlatched.JPG
Old 03-12-2015, 06:22 PM   #6
Terier's Avatar
I tend to close mine up if I am worrying about it. I used to think I worry too much until I saw someone else's awning being blown around before it ended up covering the TT.
Old 03-12-2015, 06:26 PM   #7
You need a set of poles.
Old 03-12-2015, 06:46 PM   #8
Platokidd's Avatar
Lessons learned
Lost a awning in a micro burst once its nojoy We were gone for a short period of time. Trashed the awning and had to make repairs to the small hole in the roof from the poles crashing into it.
If we gone for the shortest length time or major storm comes, the awning goes in now. Lessons learned
nights of camping
Seasonal
Old 03-12-2015, 06:48 PM   #9
I read a lot about awning hold down poles. Is there a video of what they are, how they are installed and why we need them? I have looked at all of the photos, but I can't for the life of me figure them out.
2014 Rockwood Roo 23IKSS
2012 Dodge Ram 1500 Hemi 4X4
Me, Hubby and Luna the Lab
sewingcybermom is offline   Reply With Quote
Old 03-12-2015, 06:54 PM   #10
Platokidd's Avatar
All questions concerning OC's awning poles and brackets should be made on the link furnished below" Or send OC' a pm.
nights of camping
Seasonal
awning
