Originally Posted by Loriroy
new to forum just bought a 2011 coachman concord 300i think its an ss have a slight oder inside I think I need to sanitize the tank can anyone tell me how to start owners manual is not very helpful if you have pictures that would be great
US Public Health Service
The sanitizing procedure is in conformance with the approved procedures if RVIA and ANSI A119.2 and the U.S. Public Health Service.
Use one of the following methods to determine the amount of common household bleach needed to sanitize the tank:
Multiply “gallons of tank capacity” by .13; the result is the ounces of bleach needed to sanitize the tank.
The standard solution must have four (4) hours of contact time to disinfect completely. Doubling the solution concentration allows for contact time of one (1) hour
Here is my method: The amounts listed are for my RV; you will need to calculate for your tanks:
1. Remove In-line Water Filter
2. Drain the Hot water tank, flush with city water running
3. Replace hot water tank cap
4. Add some fresh water to tank
5. 6 Oz of Bleach; 12 Oz will reduce wait time to one hour (41 gal Fresh Water + 6 gal hot water=47 gal x .13=6 oz or 12 oz for one hour
6. Fill Fresh Water tank
7. Turn on water pump
8. Turn on hot water faucet until hot water tank is full (pump will stop)
9. Add 6 gallons of water to replace water in hot water tank
10. Turn on hot water faucet until air bleeds out and smell bleach. Turn off hot water faucet and turn on cold faucet until smell bleach.
11. Let sit for 4 hours; 1 hour if used 12 Oz of bleach
12. Open all faucets hot and cold and pump out water. Pump is 2.8gpm so should empty in about 15 minutes.
13. Add one Gallon of white vinegar and fill tank
14. Turn on all hot and cold faucets; let run until dry.
15. Install Water Filter (new every 12 months);
16. Add Fresh water as needed
Note: I add the white vinegar to remove all smell of the bleach. Vinegar smell dissipates very quickly. I buy the cheapest vinegar I can find.
