Old 02-16-2013, 06:33 PM   #21
I believe it was an rg6 cable it's what came with the satellite and was supposed to have everything I needed.
Grey9712 is offline   Reply With Quote
Old 02-16-2013, 06:39 PM   #22
jimh's Avatar
well...the instructions are part of it but u have to aim before the search will be successful. if u had a dish that found the sats automatically, the instructions would work.
what i had was an inline signal meter that i used by the dish to speed up the sat location process. (had a short cable off the dish (~6') with a connector on it. i would screw that cable to a meter then the cable leading to the trailer to the other side of the meter. once i had located the sat, i would remove the meter and put a coupling in place.
when u finally get the sats located, u will be aiming abt where the others camper's dishes are aiming. the antenna is very selective and has to be right on the signal.
jimh is offline   Reply With Quote
Old 02-16-2013, 06:43 PM   #23
Okay thank you. Does anyone know if I will have to run cable directly to receiver or if I can use the port on the side of the camper?Ill call dealer Monday too.
Old 02-16-2013, 06:50 PM   #24
Stanleyg's Avatar
Your best bet is to run a cable direct from the dish to the receiver and tune in the signal, this means moving the dish around until you get a signal. Then use the cable in the rig.
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 02-16-2013, 07:06 PM   #25
Thanks everyone.
Old 02-16-2013, 07:38 PM   #26
jimh's Avatar
if ur going to aim ur dish, this gadget will help. they cost between $20 and $30. believe u can still find them at radio shack. you just plug the receiver in. attach this in the cable between the dish and the trailer. then manually aim ur dish until u get the best signal. if it isn't the right sat, aim again. the sats transmit on the same freq so u have to aim right at the one u want. ur receiver will tell u if ur on the right one.
i went to an automatic dish. just set it outside with a clear shot at the sw sky the go in and plug in. it does the rest.
there was times that i spent half hr trying to set up the old one (other times would get it in a minute).
Old 02-16-2013, 07:46 PM   #27
I'm in luck the kit I got came with one.
Old 02-16-2013, 08:04 PM   #28
I also forgot something. The kit came with this white cable that I think is referred to as a flat cable.It is not shown in the directions. What is this for?
Old 02-16-2013, 08:05 PM   #29
Stanleyg's Avatar
It is to plug into a phone jack to order things.
Old 02-16-2013, 08:08 PM   #30
It's not a phone line it's end fits in the rg6 cable.
