Old 02-16-2013, 08:12 PM   #31
If you are connecting to a cable connection the RG6 is most likely going to the regular antenna booster first. This will not work with Directv as you cannot have splitters etc. on the input side between the dish and the receiver. Disconnect this connection and connect it directly to the receiver input.
meandmylabs is offline   Reply With Quote
Old 02-16-2013, 08:16 PM   #32
Stanleyg's Avatar
Originally Posted by Grey9712 View Post
It's not a phone line it's end fits in the rg6 cable.
Do you have a pic of it?
Stan, Wanda, Sheray, Alex, Nicky, and Macky(the Chorky).
2013 Prime Time Avenger 33BHS
Stanleyg is offline   Reply With Quote
Old 02-16-2013, 08:32 PM   #33
JDWeir's Avatar
I seem to recall a flat coax cable to use for coming in through a window, its flat so that you can close the window.
YMMV
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 02-16-2013, 08:46 PM   #34
jimh's Avatar
the window feed thru would be my guess also. or if they don't have a short cable to attach to the dish, it could be used to connect there and the other end to the sat finder. that way u can watch the meter as u adj the dish.
when ur looking for the sat, turn the control (on the sat finder) all the way up then start searching (moving the dish back and forth then change the plane a little and repeat). once u get movement, try zeroing it in. adjust the meter gain (that control) down to keep the needle around half way or less on the scale.
if ur aiming a single LNB, it should be easy. if u have more than one LNB (feed horn), it is a little trickier...
jimh is offline   Reply With Quote
Old 02-16-2013, 08:54 PM   #35
I read through some old threads and it is for going through a window!This solves my previous issue now to just get the signal sorted out.
Grey9712 is offline   Reply With Quote
Old 02-17-2013, 01:58 PM   #36
I got it today!
Old 02-17-2013, 02:16 PM   #37
TURBS's Avatar
I got it today!
Great!
Turbs
Old 02-17-2013, 02:22 PM   #38
I made a box for the receiver and tried to hide as much cord as possible.I ended up having to use the flat cable but at least it works.
Old 02-17-2013, 06:09 PM   #39
jimh's Avatar
enjoy. glad u have it working!
Old 02-20-2013, 06:52 PM   #40
Freds342's Avatar
Originally Posted by Vinster30 View Post
You must use and have RG6 cable. The photo shows that your connection is for Cable and may not be RG6. You said that you did a direct connection, was that a RG6 cable?
I used RG-59 for 10+ years with DirecTV, with virtually no degradation. RG-6 is for long runs, and RV's can work fine with RG-59. My MoHo still has RG-59, and I get fine HD service. My long (50') cables are RG-6, but only because the connectors for '59 are hard to come by these days.
I just retired from Northrop Grumman as a Principal Information Technologist, specializing in Microwave, Satellite, and data communications.
There are probably a thousand websites that show the loss difference between 59 and 6 at the sat frequencies, and the short runs that we use make 59 very applicable, due to its flexibility and lack of set memory (being laid out into a particular config, particurlarly in sunny or cold spots). Short corners in 6 also cause "cold flow", moving the center conductor off center, causing greater loss than 59 might have for the same turn radius.........
Rant off!
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
