Old 07-28-2013, 07:24 PM   #21
phat phrog stunt crew
nice link for the satellite dish mount stg 1. small and lightweight.
dwaynerz is offline   Reply With Quote
Old 07-29-2013, 01:53 PM   #22
Stg1's Avatar
It's easy to set up to. just get your azimuth and elevation from the screen, take your compass and point. I made pointing easier by putting a black line on the base where the vertical pipe sits. Also I used the elbow joints for the feet that have the screw threads on one end. Then I used the screw in plugs to be adjustable. And I cut dowel pins different lengths to help with elevation.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 07-29-2013, 02:40 PM   #23
stevengb's Avatar
Originally Posted by whj77372 View Post
Gaspeddler stated it very well. If you want DirecTV HD and auto setup, it will be lots of $s. I have DirecTV at home so I thought I would use them for my fiver but not at that price. I went with with Dish for the RV because of cost. I got the Tailgater with 211 receiver, cable and remote for $199. It has worked well for us and it is easy to setup. Draw back is one TV only. Good Luck
Where did you find your tailgater and receiver that cheap?
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
