Old 07-08-2019, 07:22 PM   #1
Satellite Wired
I will throw this out to anyone that knows. I will preface by saying I contacted the factory and no one knew the answer. I have a 2019 Cardinal Luxury 3700FLX Fifth Wheel. I have an outside satellite connection in the wet box that runs to a splitter, from the splitter one goes to living room and one to bedroom. ( by the way none were labeled.) Go figure. These cables are White. The living room And bedroom satellite wall plugs have two cable connections. One is the white cable and the other is a gray cable. This is separate from the TV Cable wall plate. Here is the question, what is the gray cable for? There is no gray cable in the wet box near the sat or cable connection. I do have a Aux. connection in the wet box with nothing connected to it. Also there are no gray cables running near there. I also do not have any connection for Satellite on the roof. The official factory answer was the gray cable was for Aux. the question again is where does it connect two? I figure there is some Wire guru here that would know or is related to someone at cardinal. I did ask the the obvious to the factory is why you put the gray cable in if you canít find the end of it. My guess is they forgot to run it to the aux plug.
Any thoughts.
TonyUsfl
2019 cardinal Luxury 3700flx Fifth Wheel
Tonyusfl is offline   Reply With Quote
lite, satellite
