Old 07-24-2013, 04:08 PM   #11
rotorhead1250's Avatar
I've got the big yeller ones and some small rubber ones that I use if I'm on wood planks or leggo's for leveling. I jam the small ones in however I can and use the big ones on the non-leveled side. I want all 4 tires chocked, and to repeat again, do this before disconnecting
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 07-24-2013, 06:42 PM   #12
tanddc's Avatar
X2. I'm an over chocker too. Little ones on one side and big ones on the other. And yes, always before disconnecting almost had that lesson reinforced the hard way.(honey, should the trailer be moving backwards while you crank it up?)
tanddc is offline   Reply With Quote
Old 07-24-2013, 06:49 PM   #13
mini-me's Avatar
Our moto, to be repeated until it was ingrained in us.
Chocks in FIRST - when setting up
Chocks out LAST - when leaving.
We use the heavy black rubber ones as well.
mini-me is offline   Reply With Quote
Old 07-24-2013, 06:50 PM   #14
Dodge Guy's Avatar
When the ground/slope is questionable i leave my safety chains hooked up. I was at a site once where i was worried that if i disconnected and the trailer rolled over the chocks i was screwed along with anyone else in the trailers path! And this was our very first trip with our first used trailer.
Always becareful!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 08-07-2013, 09:27 PM   #15
Big Bad Allis's Avatar
Originally Posted by HERmit View Post
X chocks for us.
I use the X Chock and the wedge chocks for extra security. The X Chocks mostly to eliminate any movement and keeps the trailer more stable.
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 08-17-2013, 09:08 AM   #16
ryand's Avatar
I had 1st hand experience on what a trailer with only chocking one side can do on an un level site....no damage but a bit flustered. Both axles always chocked no matter how level and a natural test to ensure trailer wont move once it comes loose of the hitch. Also chains are first on, last off.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 08-17-2013, 09:11 AM   #17
ryand's Avatar
Originally Posted by Barney1 View Post
For the edification of us all what chocks do people recommend for these larger rigs (5ers and larger TTs).
This question is open to all not just the OP
I have the larger rubber ones mentioned in this thread...harbor freight at I think 7 each. They grip well on wood and lynx levelers and won't slide like the yellow plastic.
Old 08-18-2013, 09:20 PM   #18
Just Jammin 14's Avatar
Chocks and X-Chocks tire lock chocks before unhooking!
Just Jammin 14 is offline   Reply With Quote
Old 08-19-2013, 09:31 PM   #19
Dodge Guy's Avatar
If your going to get plastic chocks get the reinforced ones, not the hollow ones. the hollow ones can be flattened very easily!!!!! ask me how I know this? and don`t put them on soft ground they can easily be pushed into the earth and do nothing!
07 Cherokee 32B
Old 08-23-2013, 02:51 PM   #20
skipperW's Avatar
Another thing I don't think anyone has mentioned is that you can pull the break-away cable and engage your trailer brakes and then just re-insert it after you're set up and level. This would be in addition to chocks, of course.
skipperW is offline   Reply With Quote
