Old 05-11-2014, 07:08 AM   #1
Screen doors, New very tight
Is it normal for the screen door to be a tight fit?
You have to really push /pull them to close them.
New camper, Flagstaff 831bhds, 2014
Actual door closes beautiful though
2014 Flagstaff 831BHDS
2010 Ram 2500 Cummins 4.10s - Superchip'd
Built-in Controller
Hellwig Sway Bar 7272
Equalizer Hitch system
Long Islander is offline   Reply With Quote
Old 05-11-2014, 07:10 AM   #2
davel1971's Avatar
just a simple adjustment of the striker plate will solve that
David & Lynn
Old 05-11-2014, 07:39 AM   #3
Nope, the plastic striker plate is already out as much as possible.
Built-in Controller
Old 05-11-2014, 07:57 AM   #4
I just bought a new camper and one of my screen doors drags on the frame when opening and closing. I can't see any way to adjust it.
comfun1 is offline   Reply With Quote
Old 05-11-2014, 08:01 AM   #5
Ours was the same way. It was not square with the door opening. You have to bend it a little until it opens/closes easily. I would also check the main door's latch assembly. On ours the bolts came lose and the door opened on the highway. I would apply some blue Loctite to them.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-11-2014, 08:27 PM   #6
My sunseeker was the same way. You had to push or pull the door real hard to latch it. I removed the strike plate and drilled out the holes. Also had to grind down the one corner because it wouldn't adjust without hitting another bolt that was holding the main cabin door latch. Easy to do since everything is plastic. Once I made the adjustments it worked fine.
Pacostaco is offline   Reply With Quote
