Old 07-17-2016, 09:27 AM   #1
Second Ac in 31dbts
Hi...first time poster...yes I have a 2015 puma 31dbts with second Ac prep...just wondering if anyone knew if that opening for the second Ac in the bedroom has a slot so the Ac can be ducted or do I have to buy the non ducted control panel...would greatly appreciate any help thank u
rudpriss is offline   Reply With Quote
Old 07-17-2016, 09:37 AM   #2
Phat Phrog Stunt Crew
elind's Avatar
My Wildcat came pre-wired for a second A/C with thermostat on the wall. Ours is direct duct into the bedroom. It's nice because you can be control the bedroom temp for sleeping and even shut down the first unit if your paying for the electricity.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-17-2016, 09:45 AM   #3
Keisling's Avatar
I called FR before installing my 2nd AC and was told that all FR models with factory prep for 2nd AC are ducted. This was in 2014.
There was foil tape covering the holes where the 2nd AC ties into the ductwork. If you want to verify that on yours, just remove the bottom trim from the vent lid that's in place now and you should see the foil covered ducts on the left and right sides.
-Dave
2014 Wildcat 312BHX
2015 RAM 2500 Mega Cab 6.7 Cummins Turbo Diesel
Keisling is offline   Reply With Quote
Old 07-17-2016, 12:21 PM   #4
Thank U for replying...so it works with the other Ac and just blows the air twice as hard?
Old 07-17-2016, 12:32 PM   #5
Keisling's Avatar
I puts out twice the cold air when both are running. Most of the time they are only both running during the initial cooldown after getting to the campground or on real hot days with no shade.
The real beauty is being able to run just the bedroom unit when you want it quiet in the main living area or just the main unit when you want to sleep in peace and quiet.
-Dave
2014 Wildcat 312BHX
Old 07-18-2016, 04:07 PM   #6
How do u run them separate?
Old 07-18-2016, 05:06 PM   #7
Keisling's Avatar
They each have their own thermostat and controls.
-Dave
2014 Wildcat 312BHX
Old 07-18-2016, 05:41 PM   #8
My 2016 Wildcat 29RLX bedroom is not ducted. It probably could be though. I love it to be cold when I sleep. It is loud, but no louder than my ducted unit. I just got a tv to mount in the bedroom. Hopefully it has enough volume.
Steve29rlx is offline   Reply With Quote
Old 07-19-2016, 12:42 PM   #9
Oh...I'm only showing one themorstat in mine...maybe it's not ducted after all or works with the original
