Old 09-18-2018, 05:00 AM   #21
Originally Posted by sunnman View Post
Yes there are different ways, and thatís what I was looking for. I have decided to add an additional electrical entryway to the exterior of the TT with and internal circuit breaker. While the 20amp has a breaker at the supply, you work with the assumption that it works properly, and a second level of security doesnít hurt. Thatís why we have breakaway brakes on our trailers. Thanks to all for the input
Good choice, that will work well. Be sure to carry adapters for the 30 and 50 amp outlets as some pedestals do not have 20 amp outlets. Also give some thought to your extension cord and a 90 degree plug.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-18-2018, 05:17 AM   #22
I’m sure you will, but spend the money on a good 10 gauge chord. To heck with “less is more”, I’m a firm believer in “more is just enough” when it comes to wiring, plumbing or hvac
2006 Viking Velocity 22RS
2018 GMC Canyon Quad w/tow pkg
Nature Coast of Florida and loving it
emoney is offline   Reply With Quote
Old 09-18-2018, 11:39 AM   #23
K2Kevin's Avatar
K2Kevin is offline   Reply With Quote
Old 09-22-2018, 05:52 PM   #24
K2Kvin,
I did exactly as you have, and use the plug for an oil filled heater. I plug it into the 20 amp circuit at the pedestal, or during the winter, my home circuit. This keeps the TT nice and "toasty" warm.
Ram 2500 4x4 diesel / FR Surveyor 251rks
debit is offline   Reply With Quote
Old 10-15-2018, 12:42 PM   #25
What I did was run an entry from outside using a receptacle like K2Kevin showed, but is hardwired inside. I ran that to a breaker box with a 15 amp breaker, then to an outlet. Used 30 amp wiring inside and will use a 30 amp cable outside into the towerClick image for larger version
ID:	189276Click image for larger version
sunnman is offline   Reply With Quote
Old 10-18-2018, 10:06 AM   #26
K2Kevin's Avatar
Why a breaker on the inside? Easy shut off in case of issues outside pedestal? Im no electrician, so very curious why.
Old 01-10-2019, 03:11 PM   #27
First off I dont trust the outside breakers completely. Never know how old they are or if they work properly. For the few extra bucks to protect my investment and piece of mind itís well worth it.
Old 01-10-2019, 04:02 PM   #28
The primary function of a breaker is to provide overload protection, not provide a switch. Having your own breaker provides extra protection (as well as provide a convient switch inside in case you need it quickly.)
Old 01-10-2019, 05:39 PM   #29
Oaklevel's Avatar
When plugged into a 30A or 50A outside at the pedestal the 15A inside would trip first at 15A and not be waiting for a 50A fault.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
electric
