12-13-2015, 09:04 PM
RV Vagabond Jerry
Securing outside storage bin doors
Is there a way to make it harder for thieves to break in to outside storage bins?
12-13-2015, 09:18 PM
We changed our locks from the common keyed ones found on every rv made since 1802. Don't know what else you could do. If a thief wants in, a large screwdriver or pry bar will open almost any hatch.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
12-13-2015, 09:24 PM
Unfortunately the way most all storage doors are made, it doesn't matter what number of tumbler lock or slam latch lock you have, like said a pry bar or good sized screwdriver will allow access in just a few seconds if someone wants in bad enough.
12-13-2015, 09:25 PM
The salesman who sold us our Sunseeker pointed out the common key and advised us to not put anything in a compartment that we didn't want to loose. Of course, there are several hundred dollars worth of stuff in our compartments, and I just accept the fact that any of it could walk off. There's stuff inside the coach, too, and it's easy to open the cab doors and get in.
Damage to compartment doors caused by breaking in may be more costly than the value of what would be stolen. I know people who park in remote areas to go hiking and leave the car unlocked and with a note that it's open.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
12-13-2015, 09:41 PM
If they want in even to the inside it is not that hard........ not much that can be done..... having said that in 30 years of camping never had any one break in to the compartments or inside....... rarely lock them anyway,,,,,,,, after breaking in the thieves would be disappointed........
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
12-14-2015, 12:30 AM
RV Vagabond Jerry
How about installing heavy latches with padlocks? Would that do much good?
12-14-2015, 05:11 AM
IMO. Probably not. Bolt cutters are pretty cheap and as travel it seems a lot of people have them.
It's funny to me with guys I know that have locks on their drag tanks(extra bulk tanks) on the fill and pump side. Its advertising that it is full. If I was going to steal the fuel I have to do is cut the power cord to the pump and unscrew it or the cap side and pump it out with another pump. But I was a thief I would do the pump side and take the pump as it cost as much if not more the fuel. Just cut the lock off and you have a working pump too. They frown up cause they didn't think of it. I haven't had my fuel stole or camper broken in. Try not to be in areas where I think it might happen. But it's what ever gives you piece of mind. If they want it they don't care about what they tear up. Usually won't be in the right state of mind anyway.
12-14-2015, 09:36 AM
Campground host Mo. State
We had our previous 5er broken into and tv stolen also 30# propane bottle while in a secure storage lot.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
12-14-2015, 11:50 AM
Not really....that would probably just make the thief try harder thinking you have something really valuable In there. 😀
If someone really wants in they don't even need to open the door....a heavy utility knife will cut thru the fiberglass and foam...about all you can do is slow down the run and grab types. I've never had anything taken while using the rv. Most thefts you hear of seem to be when in storage.
12-14-2015, 03:03 PM
We've fortunately never had anything stolen, locked or not. If you're really concerned, perhaps an alarm system would be better for you.
12-14-2015, 06:42 PM
At home a couple guys popped the hasp off my shed & went right in.............. Think they used a pry bar. Figure they got in as fast as if I used a key ......The lock was still locked...... The door is a hot mess now though
1966 Mustang GT
1986 Mustang SVO
12-14-2015, 07:03 PM
Step 1 - Change out the 751 key lock.
Step 2 - In my opinion you have to decide on something that doesn't make it easy while minimizing damage. If someone really wants in and have the time & tools they will find a way.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
12-14-2015, 07:37 PM
locks are made to keep honest people honest
- from experience-
retired correction officer
12-14-2015, 08:21 PM
Canadian Member
It might be easier to park your MH in a location that's less likely to have nefarious people around. Not always possible, I know, but campgrounds tend to be places with little theft going on. As others have said, it's very easy to pop the latches on outside storage compartments.
If you have anything really valuable, look into having a safe installed inside your MH.
