Originally Posted by 2Evil4U
2Evil4U's video is correct. You will need to remove the unit from its' opening and gain access from the back of the unit. They way your unit is mounted may be different. The number, location, size of the screws & the way to access the inner workings will vary by manufacturer. Just be careful of the "reflector wheel" as it is only a long metal rod with "tin foil" ribbons that deflect the light that you see from the front. A can of computer keyboard cleaning spray would be ideal for blowing the dust etc. from this area. As he mentioned, usually the source of any noise or squeeks is the long metal reflector rod rubbing in the bracket opposite the little motor. A little dab of light grease on the shaft & bushing (if there is one) should quiet the noise.
Good luck & send pics of the process.
2014 Prime Time Sanibel 3250
