Old 09-22-2015, 08:29 AM   #21
The great suggestions keep on coming. Great point by CNYCamper! Perhaps the OP will make themselves a check list based on the responses and this thread.
2011 Georgetown 330TS
RAV4 on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 09-22-2015, 08:34 AM   #22
RollingDownTheHighway's Avatar
Pull/back into the site
check the sewer connection, make sure I can reach it (I have a mid front drain)
check side to side level - level if needed
connect electric
put slides out
level front to back
connect water
put awning out
put rug out
bring out and setup chairs
get the kids bike
open up outside kitchen
get a cup
fill cup with ice
pour whiskey in cup
sit in chair and relaxing listening to some music
when we leave, I just reverse everything with the exception electric, I disconnect electric last
2013 Prime Time Tracer 3200BHT
2016 GMC Crew Cab Duramax All Terrain
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 09-22-2015, 10:42 AM   #23
As a seasonal camper, this is an easy one. Turn on the water. Hit the button to put the awning out. Drink a beer and watch DW empty the car. Run the electric blower on the patio to get rid of the leaves and then drink another beer. Ask DW if she got everything put away yet? Go chat with the neighbors. Grab another beer and ask DW what she is cooking for dinner? Grab another beer and ask DW if she will mow the lawn tonite or tomorrow? Go visit the neighbor with the hot wife up on the corner while DW mows. Return to trailer and grab ice pack for my head and drink another beer trying to figure out where the flying fry pan came from? pretty much a routine now!
David 01 is offline   Reply With Quote
Old 09-23-2015, 07:59 AM   #24
Pretty much like most folks;
• Get a beer
• Pull TT into spot and get TT where we want it
• Check level E/W
• Get a beer (if you go real slow you can drink more beer)
• Little bit out of level –yellow blocks Lot out of level Andersen Levelers
• Block tires as needed (I like the Fastway OneStep chocks)
• Unhook from the truck
• Get a beer
• Level N/S
• Hookup Electric, Water, then sewer
• Get a beer
• Put the slides out
• Hook up the satellite
• Setup the patio
• Get a beer
If you do it right it should take 3 hopefully 4 beers to get done. You’ll need a good large ice chest.
For the tea toddlers this will take 10-15 minutes, for the heavy drinkers you can easily stretch this into a hour.
disclaimer: we traded our TT back in August for a 5th wheel so the routine is a little bit different but not much.
DKRITTER is offline   Reply With Quote
Old 09-23-2015, 11:49 AM   #25
it's all been said before but here's mine.
get situated:
check that the slideouts can be extended
place wheel chocks
unhitch and park truck
get the cat situated:
connect electrical
unfold steps
extend slides (we have no access inside without them extended)
start a/c (wife wants it going so we can move cat from truck to trailer)
move cat to trailer
turn off inverter - check that refrigerator is running properly on 110
next things:
auto level
connect water
connect park cable
turn on propane
turn on water heater
this is pretty much all that is needed at this time. other things can wait until needed (priority usually set by what wife wants)
aim satellite
do tv channel scans
connect sewer
unload chairs / pop-up / barbeque / etc
light oven pilot light
all of this is subject to change based upon circumstances - we've pretty much got it down to a routine.
CHICKDOE is offline   Reply With Quote
Old 09-23-2015, 11:59 AM   #26
Being retired military, I am used to using checklists. Did not use one for the RV until one day I left the site with the antenna still up. Luckily someone spotted it and flagged me down before I damaged anything. After that instance I developed an arrival and departure checklist for my trailer and use it every time. That way I don't forget anything which is important for me as I get older.
Windjammin is offline   Reply With Quote
Old 09-23-2015, 12:04 PM   #27
Windjammin your antenna occasion is why I suggested to the OP to tie a sash of some type to either the antenna crack up handle or to the TV steering wheel. I find the sash's more visual than waiting to check off a check list.
Old 09-24-2015, 02:49 PM   #28
Wayne Joan's Avatar
All of the checklists, routines, flags, strings etc. are good but, don't un hook from your trailer until you are sure all of your slides will clear all obstacles. I have not done this a few times and it is not only embarassing but, your DW doesn't appreciate either.
2015 Flagstaff 8528IKWS Diamond Package
2013 Ford F-150 Super Crew, EcoBoost, Max Tow,
6.5 bed, Roadmaster Active Suspension, E rated tires
91 days camped 2015
15 days camped 2016 more planned
Wayne Joan is offline   Reply With Quote
Old 09-25-2015, 09:21 AM   #29
Be ready to laugh at yourself. Forgot to chalk once. Will never forget that again, that could have turned out much worse. Didn't check slideout/awning clearance once, won't forget that again.
Campingwithsophie is online now   Reply With Quote
Old 09-25-2015, 03:42 PM   #30
blwnsmoke's Avatar
We've only camped now 4 times so far so there is nothing set in stone as far as a routine but it basically goes like this
- Back up to spot
- Push button for jacks to drop
- unhook
- push button to auto level
- while auto leveling, get electrical and water hooked up with filter.
- wife then turns on electric hot water tank.
- by this time, auto level is normally done, wife pushes slides all out as well as power awning.
- Put x-chocks on tires
- setup grill and mat.
- setup sewer
- wash hands
It is then all minor stuff there after like unloading the bikes, grabbing the chairs, unloading the firewood etc. Nothing that we necessarily do right away but still needs to be done.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
