Cement blocks or wood cribbing are both adequate for putting under your rig at a seasonal site.
Like mentioned, if you do not have a concrete pad at your site, start with patio stones for a good large 'footprint' as a base. If you use wood cribbing to stack I would recommend 4"x4"s as opposed to the 2x2 and make sure it is pressure treated. Be sure you build enough piers to fully support your frame so it doesn't twist, bow or flex.
