Old 09-27-2012, 12:00 AM   #41
Indy Steve's Avatar
I'm curious with you "Dish" guys, do you still receive your local channels when far from home? I've just started using a Directv dish on a tripod...love it as I take a receiver from home and it only takes about 5 minutes to set up know that I know what I'm doing. I knew that I wouldn't get locals away from home but have found that receiving the networks via over the air is not as reliable as I thought it would be in some areas.
Indy Steve is offline   Reply With Quote
Old 09-27-2012, 12:10 AM   #42
ironj's Avatar
depends on how far away you get....dish "spotbeams" local programming...i usually get my locals up to bout 150-200 miles out from home...but technically you are not supposed to do that...dish says you have to use the programming in the area you are in....but in order to do that you have to have them change the active zip for the box you are using....so you may get locals, but not YOUR locals.... and i agree..if you are far away sometimes getting the locals OTA is worthless...
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 09-27-2012, 08:43 AM   #43
Signal strength meter
I am currently using a tailgater, but before that I was using a Dish 500 triple LNB tripod. I used an inline signal strength meter at the dish. It had a sensitivity knob that would let you fine tune the sat. signal right at the dish tripod. It saved me a lot of time and shouting back and forth from RV to dish. I think that I bought the strength meter at Radio Shack, but the phone app might do the same thing.
wrtdotcom is offline   Reply With Quote
Old 09-27-2012, 10:49 AM   #44
ironj's Avatar
i too have a signal meter...my issue with it is that while it does a decent job of telling you signal strength, it wont tell you that your pointed at the wrong satellite like the box will...the phone app does not either, but it is handy to check line of site, and get your bracket angles all pre dialed in...of course my installer buddy has a fancy schmancy one that is digital and gives you all three feeds signal at once.....but for that price i might as well just buy the tailgaiter and be done with it!! LOL
Old 09-27-2012, 11:09 AM   #45
When I last checked to get HD with DirecTV you need a dish that is about $1,500.00! The Dish with the tailgater was about $500.
whj77372 is offline   Reply With Quote
Old 09-27-2012, 11:38 AM   #46
Earth Station's Avatar
We have Directtv and currently are 335 miles or so southwest. Satellite is the third thing done after leveling. (I have an awesome DH) Usually takes him about 5 minutes.... this time a bit more due to elevation and tilt being different......
Anyway, we still have our locals.
We purchased a carryout but didn't get 1/2 of our channels since we have HD. The dish is big and bulky but we will put up with it!!!! Not willing to spend close to 2k for a rood mounted HD winegard!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 09-27-2012, 11:47 AM   #47
We pay $5/mo for local channels, so we get whatever is local wherever we go. Just call Dish and give them the zip where we are.
Old 09-27-2012, 06:29 PM   #48
DS ADV Rider
Just to clarify, I only use the app for the camera/line of sight, and the dish settings. The SatFinder Sig strength gizmo was useless (only has audio output so need an earbud and no idea which satellite you're pointed at). I used the TV screen signal to align the dish.
We were quite close to home for our shakedown test and received all the usual channels. When we were on Bell TV we got our same Ontario programming when we were wintering in AZ. I thought it was because our account was setup for those channels so present location had no effect.
Will find out in Jan how the Shaw Direct system works in AZ.
Lacrosse 301RLS Touring Edition
GMC Sierra SLT 2500 4X4
BMW F650GS Dakar
Suzuki DR350SE & Suzuki DR650SE
Specialized FSR XC Comp
DualSport is offline   Reply With Quote
Old 09-28-2012, 04:57 AM   #49
cpaulsen's Avatar
I use a tripod. I glued some line levels on 2 sides of the tripod near where the mast goes in. Set the whole thing up in my garage(concrete floor) and made sure the tripod was level before gluing the levels on. I set the tripod up...making sure it is level the slide in the dish and mast. Use the Iphone app and aim the Dish. Usually takes about 15 minutes from start to finish.
cpaulsen is offline   Reply With Quote
Old 09-28-2012, 08:46 AM   #50
im curious (and maybe this needs to be in a thread of its own) how all of you other dish users who have to MANUALLY aim your dish accomplish this?? what is your preferred method, tools, steps, and equipment??
It has been pretty simple for me. The longest setup time I had was 15 minutes with DirectTV and that is without the meter.
  • Using one of the many phone apps, I plug in the zipcode from the GPS and get the azimuth and elevation. If other people are nearby I cheat a little and notice where there dishes are pointed. I also have the advantage of outside speakers on the TH so I turn them on loud enough to hear the signal strength beeping.
  • I get the dish mostly level, or at least level enough. The more level you are the easier to align the dish.
  • Using a compass I align the dish with the correct azimuth.
  • Next I set the elevation taking into consideration how unlevel the dish is.
  • I start rotating the dish around the correct heading for the dish while listening to the signal strength. If I get no change in signal I increase/decrease elevation and rotate around the correct heading.
  • Once you detect a positive change in signal, making small changes in elevation and azimuth, zero in on the satellite.
  • When maximum signal strength is attained lock the antenna.
75% to 85% of the time, I get the dish aligned in about 5 minutes. The longest time was 15 minutes. The only time it took longer than that (which is why I do not include it) was the time I was trying to find an opening in the trees canopy to see the bird. It took about 5 times to find a hole big enough for the dish to see the bird.
Having the meter would speed things up a lot and though it is not all that expensive, I have been getting by just fine without it...
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
ng2951 is offline   Reply With Quote
