Old 10-16-2012, 10:01 PM   #71
textman's Avatar
Yep, that is the tripod I have. Great system to get HD in the RV.
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 10-17-2012, 06:38 PM   #72
ken0042's Avatar
GASPEDDLER- I assume the 5 gallon bucket is to weigh down the dish. I had never thought of that; so simple yet effective. I assume you just fill it with water at your destination, right?
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 10-17-2012, 06:45 PM   #73
GASPEDDLER's Avatar
Yes, I fill it at the campsite and carry all my coax cables and other satellite gear inside when I'm driving. I actually switched the bucket handle to a metal handle because the plastic handle stretched as I tightened the chain. It stands up to most strong winds. BTW the tripod appears to be a surveyors tripod modified to accommodate a satellite dish. The shiny mast under the dish remains attached to the dish and attaches to the stand by way of a thread tube which is tightened from underneath the mast/platform. Prior to attaching the dish/ mast, a compass drops into that same opening and allows you to point the tripod-that's right you point the tripod-not the dish. After, while you are installing the dish/mast assembly simply line up two marks on the mast and on the tripod and more times than not you get a signal without having to use the meter.
Hers a pic of that mark.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 10-17-2012, 08:25 PM   #74
Nice operation.
glendodom is offline   Reply With Quote
