Old 03-04-2015, 10:25 PM   #1
sewer hose length
New at this how often do you Need longer than 20 feet of sewer hose? Need to know if I need to purchase a 10 foot extension
Jz5g52 is offline   Reply With Quote
Old 03-04-2015, 10:30 PM   #2
The most I have used is 20ft.
hockeyzebra27 is offline   Reply With Quote
Old 03-04-2015, 10:45 PM   #3
WFD
I can almost always get by with my 15ft....have 2, 5ft extensions if I need to add but have only needed it a couple times. Still good to have them on hand in case, cheap to buy.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-04-2015, 10:50 PM   #4
(Dry Huunday)
DreiHunde's Avatar
I've needed the 3rd 10' extension 3 times last year....I was glad I had the extra when needed!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 03-04-2015, 10:53 PM   #5
GlacierGus's Avatar
I carry a 10 foot extension but I haven't had to use it. I have used my electrical cord extension and my extra water hose so I would suggest that you carry those. Better to have them than not.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 03-04-2015, 11:05 PM   #6
Usually, if you can get close to one, then it's the others that need to be long. So I work to be close to the sewer and let the water and electric be long.
2011 Traverse LT, 3.6L, FWD
Old 03-04-2015, 11:19 PM   #7
GlacierGus's Avatar
rockfordroo, are you going to change your name to rockfordmini-lite when you get you new TT?? you know, inquiring minds need to know. Congratulations on your new trailer.
Equal-i-zer WDH
Old 03-04-2015, 11:32 PM   #8
CSMRetired's Avatar
We have a 20' and two 10' extensions. ...all of them have been hooked up a couple of times. Never hurts to have extra and a 10' extension doesn't take up that much room.
You just might end up parking somewhere where all the hookups are at the very back of the pad.
'Pa Pa's Palace'
2014 Sportscoach Crosscountry 405FK
2015 Jeep Grand Cherokee Overland
CSMRetired is offline   Reply With Quote
Old 03-04-2015, 11:47 PM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
I full time and let my 20' lay on the ground so every year I replace it with new.
donanddona is offline   Reply With Quote
Old 03-05-2015, 01:54 AM   #10
The longest hose we've ever needed was 30 ft at the 2013 Goshen FROG Rally.
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 03-05-2015, 06:49 AM   #11
Oaklevel's Avatar
We have used 25 ft often. It depends on the layout of your camper & the campground. Our TH is 36 ft & the sewer outlet is in front of the wheels. Our favorite campground has the sewer inlet located at the back so the need for 25 ft. Another newer campground we often go to has two sewer inlets on almost every site so at time I can get away with 5 foot at times. We carry 35 ft but it is rare that we need that much but it does happen.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 03-05-2015, 11:53 AM   #12
I have the 20 footer that I use, a new 20 footer still in the box and a 10 footer new in the box, just in case. They are not very heavy and I am prepared. Good Luck
whj77372 is offline   Reply With Quote
Old 03-05-2015, 12:01 PM   #13
DKRITTER's Avatar
You can’t ever have too much hose! You don’t have to buy it all at once just pick-up a little at a time.
Last weekend I had 20’ of sewer hose, needed 28’ so I borrowed and rigged up enough, when I got home I bought 2 10’ extensions.
I think I have about 100’ of water hose in 4 different hoses, with the primary water and then the flush this has always been enough.
I don’t have a 50 amp extension cord I’m a little concerned about the added distance and voltage drop probably paranoid.
DKRITTER is offline   Reply With Quote
Old 03-05-2015, 07:45 PM   #14
I don't know. It doesn't have quite the same ring to it, does it?
Old 03-05-2015, 08:09 PM   #15
Get the extension, the piece of mind is worth the couple bucks it will cost. Same for water and power, sucks to be a foot short.
Kevin
tenttotrailer is offline   Reply With Quote
Old 03-05-2015, 08:20 PM   #16
Ford Idaho's Avatar
25 feet of Rhino hose, 10' of it still unused in the box.
Old 03-05-2015, 08:26 PM   #17
Ask FT Turbs about short hoses. I think we put 30'-45' together 2 yrs ago at Goshen so several folks could dump.
Old 03-05-2015, 08:44 PM   #18
Mowgli64's Avatar
I carry a 20' and a 10', 90% of the time 10' is enough.
2015 Wildwood X-Lite 271RBXL
2019 Ford F350 CrewCab Diesel
(2013 Ford F150 Crewcab Ecoboost traded)
Mowgli64 is offline   Reply With Quote
Old 03-05-2015, 09:10 PM   #19
jtstromsburg's Avatar
1 20ft, 2 10ft, and a cheapo for dump stations. I have 150' of fresh water hose as well. Been times all of each has been used.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-05-2015, 09:34 PM   #20
Mojojojo's Avatar
I got 2 -20 ft and a 10ft with a wye , got two drains it's a bunkhouse thing...2- 10 ft fresh water 1-20ft fresh water......50ft garden hose in a reel box..... Also every power adapter known to rvers.... Better safe then short
My wife keeps saying I don't listen to her -Or something like that?...."My advice has no basis ,more reliable them my own meandering experience" Baz Luhrmann
2011 Sierra 355QBQ 1986 F350
Mojojojo is offline   Reply With Quote
