Forest River Forums
Sunline User Photos
Old 04-13-2010, 09:14 PM   #1
NWJeeper's Avatar
Sewer hose recommendations?
So my wife lost the screw in fitting for the end of our sewer hose (she swears it wasn't there) so I bought a new one and went to put it on our hose but I couldn't remove the old one and ended up destroying the hose end and clamp. I have had our hose for about 8 years now and I think it's time for a new one. I have had no problems with our present hose
However I am looking at the Rhino Flex sewer kit and wonder if anyone has had one and how they liked it. Or if not the Rhino Flex what do you use and like?
Ed & Wendy
www.nwjeepn.com
Old 04-13-2010, 09:21 PM   #2
TulsaSteve's Avatar
I bought a "Y" adapter and set it up so I have hoses run from both tanks. I used automotive hose clamps to make everything tight.
I figure when your dealing with poo, you can't skimp.
TulsaSteve is offline   Reply With Quote
Old 04-13-2010, 09:24 PM   #3
NWJeeper's Avatar
Ours all comes through one outlet and I did try a hose clamp on the old hose but it cut in and shredded the hose, maybe because of the hoses age. Cut away a couple of inches of the old hose but decided maybe I am pushing my luck with this old hose. I think it's time for a new one.
I'm with ya Steve, don't skimp on the poo hose!
Ed & Wendy
www.nwjeepn.com
Old 04-13-2010, 09:25 PM   #4
ronhanson's Avatar
I use the Rhino Flex and I'm happy with it. It has been very durable and I do like how it collapses for storage, but I do wish it would resist expanding from its collapsed state when dumping. The black out of that large connection is to much for it to resist. It insists on getting longer no matter how I try to hold it down. It looks like I'm wrestling a snake.
It's better than the Dominator hose I had that came apart on me, luckily only dumping gray.
Ron Hanson
2009 Georgetown 350TS (bunks)
400W solar, 440AH 6V GC2
2009 Ford Edge AWD Ltd towed
2011 Honda Fit Sport towed
ronhanson is offline   Reply With Quote
Old 04-13-2010, 09:29 PM   #5
NWJeeper's Avatar
Thanks for the input Ron. I have never had a hose that doesn't expand when dumping though so I sorta expect it. I usually pull the black valve slowly and let the hose fill with fluid to weigh it down before I open it all the way. It seems to help.
Ed & Wendy
www.nwjeepn.com
Old 04-13-2010, 10:00 PM   #6
grhodes50's Avatar
I've used my Rhino hose for over three years . So far no problems.
Gary & Trish
2011 LaCrosse 303 RKS Touring Edition : 2007 Flagstaff 206ST MAC Series
2010 F-250 XLT : FX4 : CC : SB : 6.8L V-10 : 4/10 Gears
2012 Nights Camped - 5
grhodes50 is online now   Reply With Quote
Old 04-13-2010, 10:05 PM   #7
2009 830RBSS
I also have the Rhino, although I've only used it once so far. It seems pretty sturdy, and the FIL is the one who recommended it to me (he's used one for a few years now and likes his).
2009 Flagstaff 830RBSS
2005 Dodge Ram 1500 4.7/4.56's
jasoncw is offline   Reply With Quote
Old 04-14-2010, 12:14 AM   #8
Rhino. It works well
Big Bird
Big bird is offline   Reply With Quote
Old 04-14-2010, 01:47 AM   #9
Yep rhino hose here too no problems so far and this fourth season for it
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 04-14-2010, 01:13 PM   #10
Rhino here too, one season so far. No complaints.
As far as the hose expanding, I always make sure to fully expand the hose out starting at the trailer connection first, then working towards the dump end. The dump end should have whatever slack is left in the hose and left collapsed. Next, make sure the hose is routed as straight as possible to the dump, making sure to only bend it within the expanded section. I used this method at the end of last season and seemed to minimize the problem. Reducing the amount of bends/turns in your hose will reduce the amount of restriction and turbulance within the hose causing less pressure to build up and expand the hose further. Hope this helps.
E.S.P.
'07 Rockwood 8281SS 5th Wheel
'07 Silverado 2500HD LMM Duramax Diesel / Allison 1000 CC 2LT S/B
Reese 15K 5th Wheel Hitch w/ Kwik-Slide
E.S.P. is offline   Reply With Quote
Close [X]
