Old 07-28-2015, 04:45 PM   #41
The_Rhino's Avatar
the Airstream will be around 30 years from now and still worth a ton of money used...
The depreciation won't keep-up with inflation & updates... 35 year-old units sell for less than $8K which is like $3K in 1980 dollars & then you have to factor-in replacing all of the appliances a couple times & reupholstery at least once. It's kinda like owning an antique car... Unless you have the knowledge, shop space & tools to do all of the work yourself they can get expensive to keep in working order...
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is online now   Reply With Quote
Old 07-28-2015, 05:36 PM   #42
Originally Posted by Stovebolt View Post
So is Aluminum.
This is a pointless post. It was stated that aluminum is thin. I pointed out that the fiberglass is thin, too. Then you state that aluminum is. Is it now my turn to point out that fiberglass is thin???
Old 07-28-2015, 07:44 PM   #43
I'm surprised Old Jerry hasn't found a way to fine you for that too!
Stovebolt is online now   Reply With Quote
Old 07-28-2015, 07:54 PM   #44
Iwannacamp's Avatar
Originally Posted by D_B Travelers View Post
Wow...so you are tent camping now?
Nope...to old and fat and spoiled to "rough it" anymore. 😎
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 07-29-2015, 06:03 AM   #45
Sometimes repetition is necessary to point out how dumb this whole post was to begin with.
Old 07-29-2015, 07:02 AM   #46
I think the question was fair enough but then you got one comment stating that aluminum trailers look "old and cheap ". Of course that is going to rub some people the wrong way! But yes, this thread can end.
larryo is offline   Reply With Quote
Old 07-29-2015, 07:22 AM   #47
mjones12's Avatar
Is there a reason why aluminum trailers could not have aluminum frames instead of wood? Just wondering.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is online now   Reply With Quote
Old 07-29-2015, 10:26 PM   #48
The aluminum is stapled to the wood studs. It would be "problematic" to attempt to attach the skin to aluminum framing.
Old 07-29-2015, 11:14 PM   #49
schrederman's Avatar
Most aircraft these days are being made of fiberglass, aramid fibers, and carbon fiber. Yes there are still some being made of aluminum, but the trend is going away from it. The techniques and glues being used to laminate RV walls have been improved a lot but as said before... not all fiberglass is fiberglass as we might know it from boats and other stuff... and where luan is used, you have to keep the water out. If it gets wet, the luan plywood layers separate and delamination is the result.
The aluminum framed, foam filled walls consist of an outer, very thin layer of some form of glass matting that was laminated to luan, with the outside finish already applied. That gets bonded to the aluminum frame, foam block insulation, and another sheet of luan with the inner finish applied already. They bond this with a polyurethane glue and use either a roller system or vacuum pressure (my preference), and heat. In my opinion, this makes a much stronger and lighter structure than the stick and tin of yesteryear...
Aluminum skins could be pop-riveted to aluminum framing, but the amount of framing needed would be very expensive... Couple that with the fact that this is very labor-intensive, and the cost jumps way up there.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 07-30-2015, 05:27 AM   #50
mjones12's Avatar
Thanks for those answers. Makes sense.
Also might be helpful to note there is a difference in molded fiberglass campers - like Casita, Scamp and Bigfoot- and the fiberglass panels like most of us have.
fiberglass
