Old 04-16-2016, 06:27 PM   #1
Shower head leaks constantly
We just purchased a 2010 Forest River Lexington GTS 255DS and when we hooked up to water the shower head leaks and does not stop. The water is pushing through the water pressure but we don't know how to get it to stop. Any suggestions would be greatly appreciated.
Bdhousel is offline   Reply With Quote
Old 04-16-2016, 06:48 PM   #2
clr
Sounds like the shower valve is leaking causing water to leak from the shower head. You may need to change the cartage or valve seat in the shower valve to stop the leaking.
clr is online now   Reply With Quote
Old 04-16-2016, 06:52 PM   #3
Thanks we will give that a try. I appreciate your feedback
Old 04-16-2016, 06:54 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Also may need to add another washer to the head. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 04-17-2016, 09:31 PM   #5
RV showers have a shutoff valve at the shower head. If the faucets are turned on and the shutoff valve is closed, the shower will appear to have a slow leak.
Recommendation:
Point the shower head at the drain and play with the valve at the shower head. If one position has lots of water coming out, turn off the faucet(s).
Phil
pmsherman is offline   Reply With Quote
Old 04-18-2016, 05:15 PM   #6
Thanks to all who responded. It appears the shower head washer was broken. Easy fix.
leak, show, shower
