Old 07-26-2016, 07:07 PM   #1
Shower question
We are looking at a 2017 grey wolf 26dbh.... Question about the shower as my husband thought he read somewhere that the shower has regular walls and does not have a surround. Has any one else experienced this??? Worried about causing water damage!
klbarnes is offline   Reply With Quote
Old 07-27-2016, 09:57 AM   #2
Senior Junior Member
Hexnut's Avatar
All the shower enclosures I have ever seen are the same, plastic enclosures with overlapping seams to shed water to the drain. I have never seen one with regular walls nor could I envision a shower built this way.
2016 Sunseeker MBS 2400R
Hexnut is offline   Reply With Quote
Old 07-27-2016, 10:00 AM   #3
BandJCarm's Avatar
Had a 2014 model. It's a surround. You'll need to caulk it, and it'll be fine.
"Next to prayer, fishing is the most personal relationship of man"Calvin Coolidge
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
Old 08-08-2016, 12:59 AM   #4
I just bought a 2017 Cherokee 274dbh. No surround in shower. Was told to just wipe down after use and will be fine
2017 forest river Cherokee limited 274dbh
Tow vehicle 2011 Toyota Tundra crewmax 5.7l v8. 4x4
kfcflores is offline   Reply With Quote
Old 08-08-2016, 10:20 AM   #5
WFD
So what material is used if no surround?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-08-2016, 10:25 AM   #6
I have a 2015 Evo (similar to GW), it has a surround. I caulked the seams for added piee of mind but to have no surround seems odd? What material is the wall then?
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-08-2016, 10:42 AM   #7
Here is a pic from the brochure. The walls look the same but I was told they have waterproof material on them. Kind of weirded me out also. But this is a very popular model and been this way a few years. I'm sure if it was horrible it would of been changed.
Old 08-08-2016, 11:18 AM   #8
trbomax's Avatar
Its probably a product called Marlite.Its 1/8" masonite that is coated on one side with a white plastic. Marlite is very durable and water resistant but the edges are not.Water gets into cracks or behind it and it swells up and the coating will start peeling.When I had the marina we relpaced a lot of it on the exterior of houseboats.It is critical to keep it caulked/ sealed at all edges or cuts.
trbomax is offline   Reply With Quote
Old 08-08-2016, 11:22 AM   #9
Interesting, I just did a search and found no shower surrounds on trailers since 1980s with a bunch of newer posts starting 2009. Im guessing it isnt a problem. A bunch of posts on other forums say the wall paneling is a sealed vinyl and for the occasional/periodic use that an entry level TT is meant for it is not a problem. I never would have thought.......
show, shower
