Old 05-15-2019, 12:59 PM   #1
ShowerMiser - how difficult to install?
AQUA VIEW SMC001 Shower Miser
I noticed that new Rockwood trailers have this device. I like the Rockwood trailers but the Surveyor 200MBLE might be a more functional floorplan for me.
I don't see the showermiser as an option for the Surveyor trailers.
But having seen the showermisor I'm smitten and would want that. So I'm wondering how difficult it would be to get to the backside of the shower for owner installation?
2007 Sequoia Limited
abehil is offline   Reply With Quote
Old 05-15-2019, 01:02 PM   #2
B and B's Avatar
Hello,
I have thought about this myself adding to my Landmark. I do use a bucket in the shower to catch cool water and let this come to room temp, use for dishes or even when warm for showering.
Old 05-15-2019, 06:21 PM   #3
RangeMaggotBob's Avatar
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 05-16-2019, 12:24 PM   #4
Originally Posted by B and B View Post
Hello,
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 05-16-2019, 04:20 PM   #5
Ugh, come on guys. B and B wasn't suggesting he was collecting *used* shower water. Just catching it until warmed up right out of the faucet.
This is actually a smart idea if boondocking. Also if you have a Rockwood Mini Lite because it might allow you to travel with less FW and we all know by the many posts in this forum about the Mini Lite tanks, the FW tank, is not very well supported and FALLS OUT ON THE GROUND if you travel with it full.
Old 05-16-2019, 07:07 PM   #6
Erinn
Hi - I'm not familiar with the ShowerMiser, but I purchased an Oxygenics shower head thru Amazon (recommended by another site), & we lover it; water gets hot faster & we have a LOT more pressure, now. I installed this myself, in about five mins. Erinn
ALSO - I read somewhere, to turn on BOTH elec AND propane, about 15-20 mins before taking a shower - this works as well; I get a hotter & longer shower now!
amazon.com/gp/product/B00F5MUB66/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Dan and Erinn
2018 Forest River Sunseeker 2420MS
TOAD: Mercedes Smart Car
06/01/18-11/10/18 Camped 43 days!
SunseekerFunseekers is offline   Reply With Quote
Old 05-17-2019, 06:24 PM   #7
Originally Posted by SunseekerFunseekers View Post
...I purchased an Oxygenics shower head thru Amazon (recommended by another site), & we lover it; water gets hot faster & we have a LOT more pressure, now.
Exactly how does the Oxygenics shower head make the water hot faster?
Old 05-17-2019, 06:41 PM   #8
Erinn
The shower head DOESN'T make the water hot faster.
I was saying that turning on BOTH the elec & propane (for water heater) at the same time helps water get hot faster, + makes for a longer shower.
Dan and Erinn
Old 05-18-2019, 12:39 PM   #9
Hi Erinn,
The ShowerMiser is quite a bit different than being an improved shower head. Even with the hot-water tank hotter, there is usually some unheated, cooled-off water in the pipe between the water heater and the shower stall. The ShowerMiser returns this clean water to the Fresh Water (FW) tanks so it isn't wasted down the sewer.
The ShowerMiser uses an extra factory-installed pipe/hose that runs back to the FW tank. Water runs in this first. When warm water starts appearing at the shower-head, one merely switches to the now warm water for that instant nice warm first wetting-down before soaping up. No precious water is wasted. In a campground with water hook-ups this wouldn't matter as much of course. But it also keeps the gray water from getting so full, if there is no sewer hook-up.
As I mentioned in another thread, I once imagined a modification by pumping, or allowing convection to force the cool water backwards down the cold water shower pipe to accomplish this. This eliminates trying to pull-or-pull another return pipe/hose through the RV frame structure in order to dribble it back into the FW tank non-pressurized filler hose.
Wes
Wes Tausend is offline   Reply With Quote
Old 05-18-2019, 01:16 PM   #10
Originally Posted by Wes Tausend View Post
Hi Erinn,
Wes
A factory plumbing diagram posted in a thread a couple weeks ago confirmed they are doing just that... plumbing the return into the cold supply line and not clear back to the tank/filler.
Days Camped: '16=46 '17=30 '18=51 '19=10
show, shower
