Old 05-10-2009, 08:54 PM   #1
UNIT6AUBURN's Avatar
Signal Booster
Is there a way to make my antenna pick up digital signals better? When I am close to a town it is OK, But 20 miles out it isn't.
UNIT6AUBURN is offline   Reply With Quote
Old 05-10-2009, 11:07 PM   #2
CampeRooo
rthrbelsewhere's Avatar
Did your new trailer come with a digital antenna or the same analog one that's be around for a while?
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 05-11-2009, 06:06 AM   #3
Chris and Sara
Is your little green LED lit up to tell you that your built in amp is turned on?? My 09 has a little botton thta has to be pushed in to activate the booster when not hooked to cable.
2004 F-150 with Tow Package
2009 Flagstaff 829 FKSS
Prodigy Brake Controller
Equalizer Hitch
renegaderailfan is offline   Reply With Quote
Old 05-11-2009, 06:51 AM   #4
The antenna you have should work fine. As stated, make sure the booster is on. You may want to add the Wingman attachment to the one you have. It's been proven to help pick up digital signals. Read the posts here about it to get some ideas of the benefit and caveats associated.
Gotta go campin!
