Old 05-17-2019, 12:54 PM   #1
Silicone melting/running
Silicone melting/running around door and windows, even on my slide seals, slide seals are pulling off when stick to silicone seal. Trying oven cleaner, brake kleen, acid tone and nothing removes it, any help, this is factory silicone, bought camper in 2010 new, camp 4-5 times a year, than sits in pole barn
ID:	204801   Click image for larger version
fj40duck is offline   Reply With Quote
Old 05-17-2019, 01:07 PM   #2
Did you put this on? It appears to look somewhat like dicor. If it is dicor, dicor is made for the roof and there are different kind (self leveling and non self leveling). For doors, windows and slide seals, pro flex or similar sealant should be used.
billybigrigger is online now   Reply With Quote
Old 05-17-2019, 01:32 PM   #3
D W
D W's Avatar
Looks like Dicor to me. Silicone doesn't melt.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is online now   Reply With Quote
Old 05-17-2019, 01:36 PM   #4
SEALANT
This is factory sealant, I HAVE NEVER PUT ANY OTHER SEALANT ON IT, THIS CAMP SIT IN POLE BARN, 4-5 TIMES A WEEKEND USE, THAN BACK IN BARN
Old 05-17-2019, 01:39 PM   #5
rmac04401's Avatar
I donít think they were implying you did this. They were just stating what it looked like.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 05-17-2019, 01:43 PM   #6
rmac04401's Avatar
The camper is 10 years old. Maybe that year they had a bad batch and after 10 years itís degrading. Is it soft now or did it drip and harden again?
2005 Honda VTX 1300
Old 05-17-2019, 05:43 PM   #7
007matman's Avatar
The best stuff I've found to take that stuff off is a Naptha based product.
Personally, I use the 3M Adhesive remover in a spray can. Seems to soften it enough to remove it without damaging plastic or paint (as long as it's removed quickly).
It's definitely not Silicone. Never use that stuff on a camper or you'll be sorry you did.
3M 08987 General Purpose Adhesive Cleaner, 15 oz. https://www.amazon.com/dp/B0002NUO6K..._0JZ3CbQMW4YBG
Most auto parts stores would have it too.
007matman is online now   Reply With Quote
Old 05-18-2019, 03:46 PM   #8
Head Rambler
That's not silicone, it's butyl tape. The sun and heat will make it soft and it can bleed kinda like that. It's actually pretty easy to get off. Most of it will scrape off with a plastic putty knife and you can use mineral spirits to clean it up.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 05-18-2019, 07:15 PM   #9
Iwannacamp's Avatar
Same thing happened to me. I used a little carburetor cleaner sprayed on a rag. Came right off.
I will say. Use at your own choice.
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 05-18-2019, 07:24 PM   #10
W5CI's Avatar
you should never use Silicone sealer anywhere on a RV
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
