Old 09-07-2011, 10:33 PM   #1
Brigitte
boubou's Avatar
Silly question
Hey I was wondering which is easiest to tow and ,aneuver
Being both same weight in trailer and tongue weight
The shorter travel traler or the longer one
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 09-08-2011, 12:59 AM   #2
flyrotor's Avatar
You'll find a lot of opinion in the answers to that question, not too sure if there is a lot of fact or case studies to support a valid answer. A lot depends on the wheel base of the tow vehicle. Mirrors play a big part here too. If you can see down both sides of the trailer clear to the rear marker lights, then your mirrors are pretty good.
Personally, I find towing a medium length (25-28 footer) is the easiest to pull if your wheelbase is long. I have not pulled anything longer than that.
A short trailer is more difficult to back up, it easily gets ahead of your anticipated turn
A long trailer is easier to back up, but takes more real estate to push it around
A short trailer is more prone to sway caused by improper loading (front or rear heavy)
A long trailer is more prone to sway from wind, either nature or forces from oposing trucks
A short trailer tracks closer to your truck's foot print
A long trailer tracks deeper, easier to hit curbs, posts, trees etc.
A long trailer will sweep outward with the rear corner as you start a turn (easier to hit gas pumps and parked cars when initiating your turn)
The closer your hitch is to the rear axle of the tow vehicle makes it more stable traveling forward, but makes you work more when backing.
The more length between your tow vehicle rear axle and your trailer axles, the easier it is to pull, so long as your wheelbase is long enough to support the length.
A long trailer on a short wheelbase truck is more likely to jacknife than a truck with a long wheelbase.
Again, these are my opinions supported from my experience alone.
flyrotor is offline   Reply With Quote
Old 09-08-2011, 06:43 AM   #3
Lottery Non-Winner
Ovair's Avatar
Flyrotor has done a good job of laying it out.
For me, I prefer a longer trailer because they are easier to back.
The short trailers cause the trailer's wheels to be closer to the hitch (pivot point) and when backing, they will jack knife in a eye blink.
I pulled a tow-able BBQ grill once for an event. When I backed up, I hadn't gone 10 feet or so and had crimped my bumper. It was because of the trailer axle to hitch distance (I was used to towing a 28' trailer not a 7 foot trailer).
Having said that, if you go too long, you'll end up with a whole different set of challenges. Pulling through tight areas with a long trailer is "iffy" sometimes. Finding spots long enough to accommodate the rig was difficult for us when we had a 40' 5er.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-08-2011, 06:51 AM   #4
MtnGuy's Avatar
I now have a 28.5' trailer. I had a 20' Trailmanor before. Even without the fold down capacities of the Trailmanor figured in, I would much rather pull that trailer than my current 1. That extra 8' makes a difference when pulling into and out of gas stations, as well as camping spots. I could get the Trailmanor in many camping sites that my current trailer will not fit. We love our trailer, but sometimes I long for something smaller.
