Denver had some pretty bad hail last week and it broke the plastic skylights over the bed and bathroom. After I get them replaced, any suggestions on protection? When I asked at an RV place, they didn't know of any metal mesh or grille product that could go on top of the plastic to protect it. Do we really just have to buy new ones every time?
I am storing it outdoors (can't afford covered storage) and haven't bought a cover yet. Is that the solution?
Thanks, Karen
If it's large hail, a cover isn't going to do much. You could have some perforated aluminum covers made and caulk them to the roof or lexan holds up pretty well to impacts.
Thanks, Karen
We got into some bad hail in Raton, NM last June and got the bathroom vent cover shattered on new camper. Had it replaced and a large heavier cover put over it. We have two skylights and it didn't damage them. Must have been very large hail. It was 50 cent size that got ours. Put several dents in side also. I was wishing for hearing protection also. Loudest continuous noise I have been exposed to. If you had it parked and not camping maybe build a cover as some others suggested, If camping doubt anything will help.
I found a large plastic storage container at WalMart that would fit over our skylight, used a ladder to place it over the skylight, tied a long rope to one handle for easy removal when we use the RV. If necessary, you could put weights on the cover to keep it from blowing off. Then I used MaxAir covers on vents. Works Great, Haven't seen any HAIL since!
I like the Lexan idea. And I don't think I would worry too much about it happening again (kind of like the lightning doesn't strike twice idea). What are the chances of it happening again or on a recurring basis? Possible? Yes. Probable? Not really (my opinion). Of course, I don't live in a hail storm prevalent area . . . you may.
Hey OC: What is the solid center of the cover for, looks like it is removable?
It is removable to be able to clean the skylight, but it's been on for going on 3 yrs and we (I) have not cleaned it. We have a lot of pine trees around and thought the pine needles would get in. No problems with the pine needles so far.
I really like OC's cover. I know it wouldn't offer near as much protection, but I wonder if spraying several coats/layers of white plasti-dip would help a little with hail?
WOW, that's sure to work. My question is why do they put a skylight in an RV. What I have found, it allows a lot of heat into the RV in the summer. That poses another question, why put an opaque window in the entry door? You can't see out the glass, it becomes another source of heat in the summer and serves no purpose. Most RV have a window next to the door anyway. Then they have the nerve to sell a insulation cover for $$, I made my own. Same goes with the skylight. Ours have been covered with foil bubble insulation soon after our first trip. They allow too much heat into the RV making the AC work harder and longer. Ours never cycles in the summer heat especially out west in LV. N. What I want in our next RV is skylight and door glass DELETE, along with all roof vents, except the bathroom vent. Their just a source of heat and possible water leaks and Hail stone targets, my opinion.
Here's what I did with one of the two skylights in ours. I hate skylights. Both are painted / coated, insulated etc, but the kitchen one is just a little more dolled up with the LED's and such. No sun, no heat. For now, the outside is just coated with liquid roof, but the whole dome will be deleted later. Or, maybe just do a cover like OC did.
__________________ John and Rebecca Dickson Emma-7 / Little John-5 / Iva-1 Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8) At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
I found some insulating inserts for mine on Amazon... but it's been a while... and I'm OLD. I can't remember what they were called. I do at least remember that they came from Camco. I used a vent cover on one of my skylights, but it's plastic, and I doubt that big hail would not go through it.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
Thanks, Karen
I seen someone cover with a large plastic storage bin turned over some weight added (firewood) to hold in place during storage.
