Old 08-24-2012, 06:12 PM   #1
Slide crank location on Salem
Where do I hand crank the main slide on a 2012 Salem hem
Cafjackracing is offline   Reply With Quote
Old 08-24-2012, 06:23 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
Need to crawl under the slide, look for slide motor near one of the rails, you'll see a bolt on the end of the motor that looks similiar to the one on your stabilizer jacks, put a socket on it and start cranking...much faster if you have a drill.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-26-2012, 01:53 PM   #3
Sealed
Do I need to unbolt the undercover of the trailer to see the motors
Old 08-26-2012, 03:39 PM   #4
Check behind your steps. It may be there, not guaranteed, but that's where a lot are located.
Len & Cheri is offline   Reply With Quote
Old 08-26-2012, 05:18 PM   #5
Camper Less Camping
Yes, to access the motor you will need to have the undercover removed.
