Old 03-31-2007, 07:18 PM   #1
Slide maintenance and lube?
Will a ‘generic’ type of silicone spray like THIS ONE work fine for the slides (and other uses) on my TT?
Or, should I go with one of the more specific ‘for slide out’ type products from campingworld.com?
Suggestions?
'05 Rockwood ROO 25RS
mn_308 is offline   Reply With Quote
Old 04-01-2007, 06:45 AM   #2
milzat's Avatar
I don't see why that product wouldn't work.
GUNK & Liquid Wrench has been around for years.
They are good products.
milzat is offline   Reply With Quote
Old 04-01-2007, 10:31 AM   #3
Thanks for the response Michael!
As I've said (many times) before.
Everything related to TT ownership is new to me...
Everyone out here on the forums has been very helpful in getting me up to speed.
Old 04-03-2007, 06:38 AM   #4
Almost any silicone spray is ok. Just watch out for anything that attracts dirt and holds it. I usually spray the slides about 3 time a year. I also use it on the leveling jacks. Makes it easier for my drill to run them up and down.
02 Chevy 2500HD Duramax ,Ally 5 speed, 3.73 gears :Equalizer Hitch
2006 Flagstaff 829FKSS
flagstaff is offline   Reply With Quote
Old 04-03-2007, 04:41 PM   #5
I just purchased a Salem 27BHBS maintenance and storage will be new to me. When you winterize a trailer with a slide should the slide be in or out?
Fitz is offline   Reply With Quote
Old 04-03-2007, 06:57 PM   #6
I leave mine in after winterizing. I don't think it matters either way, but I park mine under a tree and things fall off of it all the time so leaving the slide in keeps the tree crud off of the slide top.
Hokiehall is offline   Reply With Quote
Old 04-03-2007, 07:21 PM   #7
MrSen's Avatar
When I winterized my Roo I just used something similar to the liquid wrench. It did have a distinctive smell to it so make sure you don't lube before you head out for your camping trip.
2007 Ford F150 4X4 Lariat 5.4.
2011 8317RKSS
2006 Rockwood ROO 25rs Sold
Night's camped in 2010 36
MrSen is offline   Reply With Quote
Old 04-04-2007, 06:30 AM   #8
Fitz. We live in the northeast and the slide defently comes in for the winter. I don't want the slide or the slide topper getting a snow load and possibly knocking something out of wack. Besides the seals are just rubber and I'm sure snow can blow through them somewhere.
Old 04-04-2007, 05:04 PM   #9
Thanks for the information everybody
Old 04-04-2007, 11:36 PM   #10
Fitz,
Glad you could find some answers out here!
I think I put a poor link in the first post...
This is the product I asked about.
Here is some more info on it.
MSDS Info
For comparison I googled up the MSDS for one of the products labeled for slide out use.
Thetford Slide Out Lubricant.
I’m far from a chemist and really can’t make heads or tails of this info.
I think I worry too much about small stuff…
Old 04-06-2007, 08:28 PM   #11
there use to be a product out called dry slide it was a spray lube that dryed on contact we used this on the splitter on gear shift of the trucks we used when i was on a harvest crew out west. it was made so as to not attract dust which there seem to be an abundence of in those wheat fields.
2013 flagstaff 831flss diamond package 2014 gmc sierra 3500hd cc 4x4 sb 6.0 4.10 gears, 2000 gmc 4+4 2500hd 6.0 4.10 gears equl-i-zer jorden 2020
farmermark is offline   Reply With Quote
Old 04-08-2007, 09:24 PM   #12
welshman599's Avatar
Send a message via MSN to welshman599
I was wondering about the generic type of lube as well, as I hate spending premium dollars for "RV" products. There are generally two types I've found Wet (containing teflon/PTFE) and Dry (containing graphite). More importantly though, I acquired the service manual for the slide system from Lippert Component Industries (most of their manuals are online) and the manufacturer states:
"The Lippert Hydraulic Slideout System has been static tested to over 4,000 continuous cycles with out any noticeable wear to rotating or sliding parts. It is recommended that when operating in harsh environments (road salt, ice build up, etc.) the moving parts be kept clean and can be washed with mild soap and water. No grease or lubrication is necessary and in some situations may be detrimental to the environment and long term dependability of the system. Although the system is designed to be almost maintenance free, actuate the room once or twice a month to keep the seals and internal moving parts lubricated."
However, one of their manuals is for motorhomes combination slideout/levelling systems. It does have special instructions for those who leave their slides out / jacks down for extended periods:
"If jacks are down and/or slideouts are extended for lengthy periods, it is recommended to spray exposed jack and cylinder rods with a silicone lubricant every seven days for protection. If your coach is located in a salty environment, it is recommended to spray the rods every 2 to 3 days."
Hope this is helpful to you. I know it's what I'll follow..
welshman599 is offline   Reply With Quote
