Old 04-02-2015, 01:48 PM   #1
Stg1's Avatar
Slide out Adjustment
I need some help and don't want to take this to the Dealer. I have a Wildwood 27 RKSS with one main slide. It squeals and seems to drag especially on retracting. I know it may need to be lubed and I will do that. The front of the floor rises at the end of the retracting cycle.The slide has two bolts , one on each end of the slide, I believe are the adjustment bolts for the slide. My question is , How much should I turn the bolts and in what direction? and should I turn each bolt the equal amount of turns?. Thanks for your help in advance.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 04-02-2015, 01:57 PM   #2
fonzie's Avatar
Hope this is the right manual for your slide....
Fonzie
Old 04-02-2015, 02:17 PM   #3
Stg1's Avatar
Fonzie, Thanks for your help. I think this is my slide out system. I will try and make adjustment and post results. It may be awhile before I can do this.
slide, slide out
