Old 11-11-2014, 12:12 PM   #1
slide out brace or support
I need some opinions on slide out supports, step supports and the like. Am considering if I should invest the money on a double slide support and step support
Sandy and Steve
Chooie, Baby, Grizzly, Sophie the 4 fur babies
2018 Rockwood 8301WS fiver
2003 Ford F-250 super duty diesel
Vinemont, AL
Triple SS is offline   Reply With Quote
Old 11-11-2014, 12:53 PM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
Some folks swear by them, others say it throws the slide out of wack. I bought some for our first rig and decided they weren't worth the effort and really didn't do anything to stabilize things that we noticed
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 11-11-2014, 12:54 PM   #3
Personally I would never put something under the slide in case the trailer settles. The slides are made to hold considerable weight. As for the steps, I'm going to put something under mine as they give a bit and makes them unsteady for my wife.
Pipeman is offline   Reply With Quote
Old 11-21-2014, 09:09 PM   #4
fordsuperdutyE350's Avatar
We sit at a campground 14 weeks or more at a time. So when we stop I level everything up then get rolled up on boards for both sides then unhitch and stabilize the frame with 4 to 6 stabilizers of about 5 to 6000 lbs then roll out my slides and then put stabilizers under them. Just enough to support them, not to raise them. If you raise the slide you will cause it not to seal as good and possibly leak. My slides on my Flagstaff V-lite tilt out and down at a angle. That's natural so that water runs off away from the seals on the roof. For as long as we sit in one spot I think it's good to stabilize the slides. I have a super slide 12.6 feet wide and almost 4 foot deep. Some slides do not extend that far out or are that big. But you must remember as you go through and check things to make sure you take them out before operating the slides.
fordsuperdutyE350 is offline   Reply With Quote
Old 11-21-2014, 09:51 PM   #5
Plain Old Member
No problem stabilizing slides, until a tire goes flat or something settles. We've never used them, and never will. I've never seen any manufacturer recommend them. Everybody has there reasons to use, or not to use.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 11-21-2014, 11:55 PM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
I don't support the slides. I re-level weekly. And I always brace the steps (simple screw bottle jacks) when I've setup. Also, I use hydraulic bottle jacks under the front axial to take the bounce out (thanks OC!).
donanddona is offline   Reply With Quote
Old 11-22-2014, 02:28 AM   #7
Witch Doctor's Avatar
I would say no to the slide supports, for reasons given already, But I do recommend a step support. OC made mine, and it's the best thing to stop movement going up and down the steps, wouldn't be without it now.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 11-22-2014, 02:58 AM   #8
I tried slide supports on previous trailers, but did not like them. I found adding more scissor jacks to the frame gave me the stability I was looking for.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 11-22-2014, 04:46 AM   #9
ARLO
If you have lippert steps I would be definitely suggest step supports AND replace the crappy rivets they use to hold them together. Nix on the slide supports.
rlocicero is offline   Reply With Quote
Old 11-22-2014, 06:06 AM   #10
Remember these travel trailers were not designed to handle being used full time. So there are times when you have to take extra precautions. We plan on having this TT for a few years. I should say the frame is stabilized by heavy duty scissor jacks. We are basically full timers. The reason the factory does not recommend them is people will forget to take them out or misuse them. And as I say if I have a flat tire I have the frame supported. Enough said about this subject....
slide, slide out
