01-30-2019, 09:15 AM
Jayhawker
Slide out nearly misses cabinet pull
Noticed that there is not much clearance (when the slide out is retracted) between the slide out and upper cabinet pull. Maybe 1/32". Concerned some day it will hit the pull and tear something up. 2018 Surveyor 243RBS Any body lost a cabinet or pull yet?
01-30-2019, 10:10 AM
Yep. My experience is that slides do move occasionally and need to be adjusted. I had one large hydraulic slide that the outside trim came within an inch from the side wall. It moved and got close enough to the wall to break the cover off of an electric plug box (the slide trim caught it just right). I was amazed it didn't pull the whole box out of the wall. Had the slide adjusted and now it has remained about an inch and a half from the wall.
Have some friends with a large schwintek slide that always has problems and will start coming in or going out unevenly. They have replaced their cabinet door twice and the whole cabinet once. They will be replacing their whole RV as soon as they can, for one without schwintek slides
I would either replace that pull with a different type, or at least see what a tech says about adjusting the slide. I agree with you, it looks like an accident waiting to happen.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
01-30-2019, 10:38 AM
Always Learning
Good freaking luck. I wanted to get away from them, too. Everything I looked at and liked had at least 1 Schwintek slideout.
I agree. I'd either be removing that handle each time or replacing it with something else. That's definitely going to get ripped off of the frame at some point.
01-30-2019, 11:01 AM
Yeah, that's Waaaaay too close for comfort!
Does the slide room look to be centered in the opening?
Gotta go campin!
01-30-2019, 11:13 AM
I agree... a little too close for comfort.
We had a SOB unit with something similar.
I drilled holes in the cabinet door the same size as the standoffs on the handle and then put washers on the back with the screw. This allowed the handle to 'push into the door' so it was flush but pulled out when needed for clearance. This of course requires that the mounting of the handle isn't directly in front of the inner cabinet face upright. Mine just missed.
01-30-2019, 11:14 AM
I hear you. We can find some that only use schwintek on the small lighter slides, like the bedroom, where they seem to work better. But if it is on the larger slides, we just walk away
01-30-2019, 11:20 AM
X2... we're looking at several new 5th wheels at the moment but finding the same.
Not sure if we'll replace what we have just for this reason.
It seems those with slide problems are Schwintek 10 to 1.
Sorry for the thread drift... back to your regularly scheduled programming...
01-30-2019, 11:27 AM
We are in exactly the same place . It's going to have to be a hell of a deal on an otherwise perfect RV for us to accept even a little schwintek slide . Maybe in a few years they will finally either perfect schwintek or use something else that works. We are not in a hurry.....
We have had too many friends and acquaintances that have never ending schwintek problems. Granted, most of them are on the bigger, heavier slides.
01-30-2019, 11:56 AM
We had one of our silverware drawers pop open while driving. Pushed the slide out and heard a crunch. Got lucky and had the damage repaired under warranty. Now we do a visual check of several items before moving the slides - tv, drawers/doors in kitchen, doors on wardrobe slide....
Still thinking about a design to insure the drawers stay closed - may do kid latches or some kind of bar on the handles during transit.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
01-30-2019, 12:37 PM
One of the things I do to every new RV of ours is install new 10-15lb pull catches on all the drawers and cabinets. No more inadvertent openings. Don't know why most catches they use are so wimpy... Oh wait, yes I do
01-30-2019, 02:17 PM
I had a cabinet door open during travel. It was behind the slide and caught the edge while sliding out. Luckily it caused little damage. I since installed spring hinges from Lowe's, no more trouble.
01-30-2019, 04:45 PM
Canadian Member
Our new 2019 Rockwood Signature 8290BS has rear opposing slides in a rear kitchen floorplan. There are soft closing drawers next to the slides. It looks like there is a few inches of clearance and the soft close mechanisms should hold the drawers closed without any changes. The handles don't stick out like the OP's. The cabinets doors however might need a childproof lock type thing for some piece of mind.
No Schwintek slide for me either!
01-30-2019, 05:31 PM
don't forget the worst slide mechanisms
By accu slide cable operated . would rather have a schwintek . the problem with schwintek is they just can't handle the big kitchen slides or the very long whole room slides . but the smaller dinettes or small bedroom closet slides they seem to work very well imo
01-31-2019, 07:54 AM
Those smaller MH that have the hole side is a slide out,,,
Is pretty Damm Scary !!!
