Old 09-29-2014, 06:11 AM   #1
Slide outs
365saq
cabinetmaker61 is offline   Reply With Quote
Old 09-30-2014, 06:05 AM   #2
Slide outs stop about half way through cycle
Old 09-30-2014, 06:12 AM   #3
jonrjen's Avatar
Have you checked your hydraulic fluid level? I am of course assuming that your slides are hydraulic and not electric slide outs.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 09-30-2014, 06:25 AM   #4
jtstromsburg's Avatar
Do they start again our will they not go past halfway? If they start again, it could be a bad battery or bad auto resetting fuse/breaker. If it won't start again, then like jonrjen said, check fluid level or look for obstructions.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 09-30-2014, 10:08 AM   #5
Well it has 4 slides.
Most of them will slide in but when it gets to the last one alot of times it will stop.
If you let the button up for a few seconds it will start to operate again
Old 09-30-2014, 10:09 AM   #6
I just recently replaced the converter.
Don't know if that will fix the problem or not
Old 09-30-2014, 10:13 AM   #7
If it were me, is disconnect the battery and test it. Check voltage at the battery with no draw. Last year my friends camper did the same thing and he replaced the resetting fuses and still had to buy a new battery, but that fixed it.
Joel and Teresa
2016 Sabre 34TBOK
slide, slide out
