Old 07-11-2014, 10:42 PM   #1
Slide Problem
So after fixing a disconnected cable and replacing the slide switch, which I thought was an issue. My slide worked in my driveway 8-10 cycles.
I take it to the campsite...nothin'
It's an Accu Slide with a Norco high torque motor.
Is there an in-line fuse that I am missing?
The FAQ says if the motor makes no sound it is a bad controller or bad motor.
Before replacing the motor, what I assume is a big job.
What is the controller? How can it be checked?
Also the slide is fully retracted,,,extending it is difficult as the provided rachet is not long enough.
Help please?
Craig
Yellowknife,NWT
Canada
Tracer 3150 BHD
Silverado 1500 Crew
2damcold is offline   Reply With Quote
slide
