Old 09-26-2006, 06:18 PM   #1
Question slide secure bar
Have you ever gotten a bit down the road and realized that the slide room security bar to be inserted on the top of the slide room has not been put into place? Wondering how often this bar is used since leaving the 'show room' floor and hitting the road. Anyone not using this bar?
Road Runner is offline   Reply With Quote
Old 09-26-2006, 06:42 PM   #2
Bear's Avatar
I have had 3 trailers with slides, 2 hydralic and 1 electric and I have never used them. Actually, I have never had a set come with a trailer.
Cheers
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 09-26-2006, 08:09 PM   #3
milzat's Avatar
I've got a set of slide lock(secure) bars. Came with the TT.
Have never used them. Slide has not moved on me.
milzat is offline   Reply With Quote
Old 09-26-2006, 08:30 PM   #4
I have a slide lock bar that I have never used or needed to use. It stays behind the couch on the floor out of the way.
Hokiehall is offline   Reply With Quote
Old 09-26-2006, 08:52 PM   #5
slide lock bars
So, what might be the reason for the dealer including the slide lock bar? Seems they don't 'give' anything 'free' without a good reason.
(Scratching my head on this one.)
Old 09-26-2006, 09:26 PM   #6
Mine was supplied by Forest River. In fact my dealer suggested not using it and if I noticed the slide opening while traveling to get back to him ASAP to get it repaired. He said he gets a lot of repair work from people who forget to remove it and then tear the front facing off the interior slide cabinet doors, even though there is a tag on the slide lock to flip over to remind them to remove it before opening.
Old 09-26-2006, 10:02 PM   #7
GandBL's Avatar
My family just purchase a Flagstaff 27BHSS. The delivery specialist (HaHa) and myself inseted the slide locks prior to us departing the dealership. We traveled approximately 50 miles home. After entering the trailer I noticed the slide locks just laying at the top of the slide.
After reading the instuctions about the use and installation of the slide locks they are only to ensure a prooper seal at the top of the slide during travel. Are they needed? When the slide is closed in our trailer I can grab the top of the slide and put some pressure outward causing light to enter the seal area.
I'm not sure wether or not I will use them. Reason? When inserted and secured the pad at the slide end places alot of pressure on the extending side of the seal. I feel the the pressure will cause excessive wear and premature failure of the seal. I may be wrong but it seems like common sense to me.
Has anyone seen the non use of the seal cause leaking or excessive dust during travel?
Happy Trails!!
GandBL is offline   Reply With Quote
Old 09-26-2006, 10:10 PM   #8
milzat's Avatar
Ditto. Same here.
I installed the locks once, just to see how they fit. I didn't care for the way it put undue pressure on the slide seals.
Old 09-26-2006, 10:17 PM   #9
milzat's Avatar
When the slide is in the transport position, it closes so tight, I can not move it at all.
No, not I.
Old 09-27-2006, 06:33 AM   #10
I have a Flagstaff 29FKSS and never thought about it. Either my wife or I always use them. But they have big orange tags that hang down so it's kind of hard to miss if there in. Maybe I'll try not using them this weekend.
02 Chevy 2500HD Duramax ,Ally 5 speed, 3.73 gears :Equalizer Hitch
2006 Flagstaff 829FKSS
flagstaff is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Slide out stops working bigbud450 Salem 6 04-09-2007 09:12 PM
Slide Awning MRimmer Flagstaff 8 11-24-2006 06:59 AM
Need rear bed slide info MOD Guy General Community Discussions 4 11-21-2006 09:22 PM
