Old 10-02-2010, 02:22 PM   #1
Question slideout lube & wheelbearing lube
I have a 2010 surveyor sv302. the owners manual doesn,t list any spec,s for lubeing the slideout rack and pinion or what type of grease for the wheel bearings, i belive the wheel bearings are called super lube hubs. the manual, the way its set up is worthless.
quietman is offline   Reply With Quote
Old 10-02-2010, 03:19 PM   #2
NWJeeper's Avatar
Manuals for RVs don't tell you much, you need to find litrature from the slide manufacturer. Forest River's slides are in most cases made by Lippert Inc. You can usually use a silicone based "dry lube" that comes in a spray can. It is available at Walmart and RV supply stores. Grease and oils like WD40 can attract and hold dirt and dust and are not usually recommended.
Ed & Wendy
www.nwjeepn.com
Old 10-02-2010, 11:12 PM   #3
Hatchet58's Avatar
. There is something out there thats called SEAFOAM. a silicone based spray, and 100% better then WD40
Hatchet
Chevy 2500HD Diesel
07 SandPiper F305
Days camped 2011 "3" so far,
Hatchet58 is offline   Reply With Quote
Old 10-03-2010, 05:30 AM   #4
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Can you be a bit more specific? Perhaps a link?
dimurrrw is offline   Reply With Quote
Old 10-03-2010, 06:29 AM   #5
Wanna Be Camper
SaskCampers's Avatar
Seafoam makes a fuel treatment, engine/tranny additive and a product called deep creep.
Sea Foam | Products
But their products are awesome, alot of boaters use the fuel additive as it helps with problems associated with ethenol fuels in boat engines. I use it in my old small engines and as a tuneup every once in awhile in our vehicles.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-03-2010, 07:20 AM   #6
AKA Bluebird
dimurrrw's Avatar
Sea Foam | Products
Right you are! I had checked this out before making my earlier post. My difficulty is that I didn't see anything in the literature that mentioned silicone, as stated by Hatchet58. Did I miss something?
Old 10-03-2010, 07:25 AM   #7
MtnGuy's Avatar
Yeah Richard, I didn't see anything silicone based either. Deep Creek is petroleum based, which would probably leave a residue to collect dirt.
Old 10-03-2010, 08:07 AM   #8
AKA Bluebird
dimurrrw's Avatar
Chap, I share the same thinking.
Old 10-03-2010, 08:22 AM   #9
Wanna Be Camper
They have no silicone based stuff. It is roughly the same as PBlaster or Fluid Film both of which are super items for their intended purposes but not for this particular thing.
John & Deb
