Old 02-22-2013, 06:18 PM   #1
kc8lvy's Avatar
Slides and cold weather
We are still in some cold weather here in Michigan but we want to start packing our new camper up and getting it ready for a nice weekend if we ever get it.
My question is Is it better to leave the slides open or close them up in 20 to 30 degree weather. We will probably only work on packing during the weekends.
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 02-22-2013, 07:03 PM   #2
I would be concern about leaving slides out in winter. A couple of thoughts, and I may be way off base, but:
1. Snow loading and a cantilever effect if you got a major snow fall
2. Exposure of seals to dry, cold weather with UV exposure
I am sure more people with more knowledge and experience will chime in.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 02-23-2013, 02:13 PM   #3
Whiteknight's Avatar
I keep mine closed all winter, don't want the snow and ice build up on them. But I wouldn't have a problem opening them up to load stuff in there and then put them back in when finished. I would just make sure the seals are dry and that there isn't a possibility that the seals could be frozen and stuck together.
2012 Flagstaff V-Lite 30WFKSS
2015 Ram 2500 Big Horn Mega Cab 4X4
Whiteknight is offline   Reply With Quote
Old 02-24-2013, 11:40 AM   #4
Silicone spray, WD40 and even Armor All work well on keeping the seals moist and soft.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 02-24-2013, 12:02 PM   #5
Chip2830's Avatar
Mine and others here in the cg have our slides open all winter. The only time we have brought ours in have been during the high winds other than that open.
Chip2830 is offline   Reply With Quote
Old 02-24-2013, 12:24 PM   #6
That question is different depending on your location. Given you are in a high snow area like us I'd retract them to ensure you don't get snow on them. Also, be very careful, when it's real cold any material can get less pliable and more prone to tearing. Be careful!
mwebber78 is offline   Reply With Quote
Old 02-24-2013, 12:44 PM   #7
mduff's Avatar
Heard of an incident where the TT was not leveled, slide was open in the driveway to do maintenance, and left open for a period. Water accumulated and ran into the TT. Agee with others that the opportunity to get snow build up, and/or water freezing and preventing the slide from closing properly would also be a concern.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 02-24-2013, 12:51 PM   #8
kc8lvy's Avatar
I will definitely keep this in mind. I have them open right now but i plan on closing them on Monday before the weather hets bad
Old 03-15-2013, 04:19 AM   #9
MI Camperz
bodzcampers's Avatar
What would be the reason to keep them open? Think of it that way.
bodzcampers is offline   Reply With Quote
Old 03-15-2013, 10:39 AM   #10
kc8lvy's Avatar
The main reason I was asking we were loading it up to get ready for camping. I didn't want to have the slides going in and out when it 30 degrees out. We ended up leaving them open a few days while the weather was good, then closed them up before it snowed.
