Old 06-14-2016, 05:54 AM   #1
Slides open or closed when TT is on driveway
Being new to the TT world i have a question.... Is it better once my TT is home to retract the slides (i open them when i get home from a trip to clean the TT) or keep them open? I have slide toppers. I am camping every other weekend so the TT is not stored on my driveway with the slides open for long periods of time. Thanks for your comments.
Joe from Long Island
jasanto is offline   Reply With Quote
Old 06-14-2016, 06:10 AM   #2
It is totally up to You if slides are "In or Out"! Youroo!!
youroo is online now   Reply With Quote
Old 06-14-2016, 06:10 AM   #3
Prime Member
It's a matter of personal preference. Either way is ok.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-14-2016, 06:11 AM   #4
CAT-RN's Avatar
I don't have a TT but my logic has alway been to run the slides as little as possible.
So if you run them out when you get home I'd just leave them out till I was ready to leave again. Might want to load or clean on it while it setting there. No reason to run them in and out several times. Just my thoughts.
Russell
CAT-RN is online now   Reply With Quote
Old 06-14-2016, 06:18 AM   #5
Since we have to use a storage lot we clean the camper at the campground then run the slides in and leave them in. If I could park it at home I would probably leave them out since stepping on the slide floor and damaging it is a real possibility.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is online now   Reply With Quote
Old 06-14-2016, 09:48 AM   #6
I leave mine out due to the layout of the trailer. The motors are HD so as long as you are not stopping and starting or running with the last gear at the end of the rack, I think it would be a tough chore to burn them out. Not to mention easier access for cleaning and maintenance.
Kevin
2009 F150 XLT crewcab 5.4L and 3.73
2010 Flagstaff 27 BHSS
tenttotrailer is offline   Reply With Quote
Old 06-14-2016, 10:06 AM   #7
Pickin' & Campin'
It's totally your preference.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-14-2016, 11:15 AM   #8
grumpy0374's Avatar
Used to leave them out all the time when at home.
Then got to thinking...
No reason to leave the slide out toppers constantly exposed to sunlight/heat/uv when not necessary. Yes, I do treat them regularly with 303, but still why subject them to "extra" ware.
Also, when real hot/humid, I'll run the ac. Closing the slides cuts down on cubic footage the ac has to cool down. Have the foil/bubble insulation covering all the windows while at home, and that helps alot, but closing the slides also helps.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-14-2016, 11:28 AM   #9
RollingDownTheHighway's Avatar
Your preference, but I open our slides out about a week before our trip and then leave them open for about a week when we get home from our trip. I usually do a pre-trip and post trip inspection of everything from top to bottom before we leave and when we get home.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 06-14-2016, 05:54 PM   #10
Stormrider151's Avatar
It's your call. Either way is fine. If you leave them out I would be sure to treat your seals with something like 303 to keep the sun from drying them out.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
slide, slide out
